I recently started down the path of something I've been wanting to do for fun, build an engine.
Not sure how to even do a compression test, but I am guessing if I could do one before I tear apart the motor that would be best. The motor came with out a car , it is a 1.8L miata motor. Items missing from this motor... no transmission, no fly wheel, no exhaust header and no intake manifold.
Can I do a compression test with out the motor in a car?
you could concievably do a leak down test instead, but it would be tough w/o a fly wheel to secure to crank in a position during testing.
btw, a leak down test is when you use air from an air compressor and a pair of gauges connected in serries to fill the cyl (with piston set to tdc compression) with air at a set pressure, and then see how much it actuly holds and for how long. This is a usefull test when you have a compression loss but can't figure out wherre it is going, you can listen and check for whee the air is leaking to because you have a constant supply going into the cyl.
A leak down test would be much easier to do in this case than a compression test and will actually give more information as HA said.
ignorant wrote: if you can spin the crank you can do it. big bar or large air wrench...
I've tried that before, but could never get enough RPM to get a good reading. A leakdown test is more meaningful anyway.
I have done a compression test on a small block chevy on an engine stand, the starter bols to the block on those though.
