M030
M030 HalfDork
5/1/13 10:07 a.m.
I just impulse-bought a second one & I'll combine the two to make one great one. Then I'll berkeley it up by sticking a Vette motor in it
NGTD
NGTD Dork
5/1/13 11:24 a.m.
They did a RWD Volvo one a long time ago and I think the 960 was briefly mentioned but it focused on the Turbo Bricks (240 and 740).
ransom
ransom GRM+ Memberand UltraDork
5/1/13 11:45 a.m.
Apparently the April 2004 issue covered turbos...
Hey, the web version even saved me asking whether I was correct in recalling that the 9 is a facelifted 7 (it is).
This thread was third in my search results for "volvo guide" on grassrootsmotorsports.com.
Tim Baxter
Tim Baxter PowerDork
5/1/13 12:26 p.m.
I wrote it, quite a while back. Does mention the 940/960, as they really were just updated 740/760
http://grassrootsmotorsports.com/articles/volvo-turbos/
Don't know why it says Alan wrote it.
M030
M030 HalfDork
5/1/13 2:19 p.m.
Thank you
11110000
11110000 Reader
5/1/13 2:37 p.m.
As you've discovered, the 960 is more or less a facelifted 760. The 9-series rounded off a few corners, and the sedans got the more sloped rear window/higher rear deck design. Under the sheetmetal, the 9's have SIPS (Side Impact Protection System) which beefs up the shell a bit.
Probably the most significant variable in the 960 series is the rear suspension. The 92-94 960 sedan carried over the multilink coil spring suspension of the 960, while the wagons had the good 'ol live axle. In '95, the 960 got a facelift and moved to a transverse composite leaf spring independent rear (like the Corvette), and this was used in both the sedan and wagon variants. The 95- models also used the higher positive offset wheels that the FWD models (850/S70/V70) wore.
BoxheadTim
BoxheadTim GRM+ Memberand PowerDork
5/1/13 2:48 p.m.
IIRC the 760 has the PSA V6, the 960s at least in Europe have a Volvo straight six. Completely different engines.
PEUVC1tLPvtyV4xqBW8S6yh3GpY4hnSOD5M1dQgKPSWSPZNXk7Le9cCbrgUNeu93
