1 2 3 4
mr2s2000elise
mr2s2000elise UltraDork
6/10/21 8:07 p.m.
John Welsh said:
Here's what you probably want to know the most... you can resell it and get your money back pretty easy if it turns out you don't like it.
Other than that, it's a big metal box but this one has carpet and stuff throughout.
A cutting edge design in 1996 (25 years ago)
I rather have a sienna (doesn't fit my needs) or NV 3500 (don't want to spend that now)
on paper a used 3500 checks all my needs
scheduled inspection and drive tomorrow. Will report back .
in a hot  market it's been on sale 16 days. Not every one wants it I guess
mr2s2000elise
6/10/21 8:08 p.m.
californiamilleghia said:
I made sure I got the sliding side door ,  was easier for me to load things in a parking lot ,
there is tons of room in them ,  and the spare tire is stored under the back area and removed from the bottom ,  the jack is in the back passenger corner.
mine is not extended , but if you need me to measure anything just ask :)
Appreciate it my friend
sliding door is a must. I already have fj cruiser with clamshell don't need another
wish it had dual sliding - but not a deal killer
 like that on 3500 extended wheel base is not all after the rear wheels. Thus proportion looks fine
seems as long as my new DCLB tacoma , which is good
mr2s2000elise
6/10/21 8:09 p.m.
Cadman5 said:
In reply to mr2s2000elise :
You could give the front wheels a shake to check bearings and steering, but frankly, it's all so big and stiff that I could hear the bearing but couldn't really feel any looseness. You might be able to see/feel really bad ball joints, but again, big and stiff, so sometimes hard to tell unless really bad. Just plan on front bearings/hubs and idle arm/pitman/tie rod ends soon.
Thanks! Will keep an ear out on test drive tmrw
6/10/21 8:30 p.m.
From the description the price sounds a bit high, but if it's really nice maybe not.
A local place had an E250 that had no rockers at all and generally looked beat to E36 M3, with $6000 on the windshield, and it was gone within two days, so... probably not?
6/10/21 9:42 p.m.
In reply to Pete. (l33t FS) :
Wow! I don't see many passenger vans on marketplace here, but early-mid 00's E-series are rarely that expensive - and they're not usually rusted out here either(unless it's the roof).
mr2s2000elise
6/10/21 9:45 p.m.
Anybody have a right number for this that I should offer ?
mr2s2000elise
6/11/21 11:12 p.m.
Are you able to measure the cargo area behind the last row?
I am trying to see if nissan nv3500 has more or less luggage space.
mr2s2000elise
6/11/21 11:15 p.m.
Test drive
  • oil was a bit dark.
  • roof faded
  • headlights faded
  • van is mint inside
  • outside the front and rear door both has long scratches in paint. Almost looks keyed. He bought it that way
  • drive fantastic. My first time in a 6.0L in at least 5 years. Trans shifted great
  • no leaks
  • ac cold
  • power front seats
  • tow package
  • there is a loud squeak/rattle from rear door. Research says they all do that.
Guy won't negotiate a dime. Said been online for week. Few calls. Nobody came to look yet
Cadman5
Cadman5 Reader
6/12/21 12:11 a.m.
Sorry, all my seats are out right now for moving a college kid. The very last row in mine (15 passenger) is pretty much right against the rear doors.
If you measure from the back of one of the other seats to the back of the one in front of it, that's how much is behind your last row.
mr2s2000elise
6/12/21 1:02 a.m.
Great thanks
debating pulling the trigger. We are about $2500 apart
John Welsh
John Welsh Mod Squad
6/12/21 3:29 a.m.
mr2s2000elise said:
Gotta love that VIN plate says "BUS, but NOT a school bus"
I can't read the entire tag for tire size but I can see that the van calls for E load range tires.
In my experience,  these GM vans are hard on front tires.  When I super zoom in on the tire photos, I see worn outside shoulders on the front tires.  I can make out the partial word, Discover on the tires, this means Cooper Brand tires.  Popular tires but not my favorites.
More so, I suspect these are not really E load tires but lesser load range tires.  As a 3500 van, these are heavy beasts.
In summary,  it is just my guess from pictures that you may need 4 tires.  Expect a real tire replacement cost of $225 per tire, mounted or $900, rounded to $1k.
The rear tires might show good remaining tread but if they are not really E load tires you're rolling unsafe on an under-spec tire.   What that could mean is faster wear and more prone to a  blown tire.   If reliability is your number 1 priority, then road side tire repair is probably something you'd like to avoid.  Furthermore,  avoid the accidents caused  by the failure of an under spec tire.
Maybe use that as negotiation.
To me, from the 2:00 to 4:00 positions of this tire, the outermost tread block looks completely rounded off
The tires are probably HT3s but notice how the outermost tread block should look.  Cooper's site does say these HT3s are offered in E load also.
So, maybe not wrong spec but I still suspect very worn outer block.
6/12/21 5:47 a.m.
In reply to John Welsh :
Fwiw I just put new E-range A/T tires on the E250 in April & it was just over $800. Non-A/T tires would have been quite a bit cheaper though.
Also, Fords are definitely known for chewing up front tires, but I'd not heard that about GM. Although I owned my 99 Chevy Express 3500 longer, I've put more miles on the 06 E250.
mr2s2000elise
6/12/21 8:44 a.m.
Very good point! Definitely worn tires on outer.
245/75/16 OEM size
these are tires currently on it
https://m.tirerack.com/tires/tires.jsp?tireMake=Cooper&tireModel=Discoverer+HT3&partnum=475R6DHT3&vehicleSearch=true&fromCompare1=yes&autoMake=Chevrolet&autoYear=2009&autoModel=Express+Van&autoModClar=G3500+8-Lug%2C+Single+Rear+Wheel&autoMake=Chevrolet&autoYear=2009&autoModel=Express+Van&autoModClar=G3500+8-Lug%2C+Single+Rear+Wheel
mr2s2000elise
6/12/21 8:51 a.m.
In reply to Pete Gossett (Forum Supporter) :
Which brand tires did you buy?
John Welsh
6/12/21 8:55 a.m.
Not to pile on but why so worn tire shoulder?
Worn front end parts?
I like shopping cars with old tires. If the seller slaps on new tires, this can often hide the visible evidence of other issues.
mr2s2000elise
6/12/21 9:00 a.m.
Possible. But nothing was amiss on the drive
but I didn't really was able to inspect anything on his driveway
other than - underneath was clean, no leaks
maybe as cadman says above "Just plan on front bearings/hubs and idle arm/pitman/tie rod ends soon. "
if that's the case - maybe I just save my pennies for a newer NV3500
John Welsh
6/12/21 9:16 a.m.
I'm not trying to scare you off this red van, I'm just trying to give you ammo for negotiating a price reduction.
$1k off for tires and maybe another $1k off for front end questions.
You might have reasonable evidence to get the seller to move on his price.
mr2s2000elise
6/12/21 9:19 a.m.
Thanks John! I will try in 2 hours when I have a call scheduled
hes from OKC - I am expecting a hard "no" given how he was yesterday .
mr2s2000elise
6/12/21 12:56 p.m.
This just popped up
1500 lt
2011
87k miles
awd
but only 8 pass
californiamilleghia
californiamilleghia SuperDork
6/12/21 12:57 p.m.
6/12/21 2:15 p.m.
mr2s2000elise said:
This just popped up
1500 lt
2011
87k miles
awd
but only 8 pass
Buy it & bolt in shuttle bus seats. They're usually $25-each used.
californiamilleghia
6/12/21 2:21 p.m.
is that the normal size one and not the extended ?
if you have a picture of the sliding door , the rear edge of the door is only a few inches from the wheel well arch.
6/12/21 2:34 p.m.
I got Kumho Adventure -AT51's from Tire Rack.
Mr_Asa
Mr_Asa UberDork
6/12/21 5:09 p.m.
My not-really-a-brother-in-law just picked up something in this range.  He usually flips vehicles.  Lemme talk to him and get specifics.
mr2s2000elise
6/12/21 6:46 p.m.
mr2s2000elise said:
This just popped up
1500 lt
2011
87k miles
awd
but only 8 pass
That's a no go. Wants $29,000
1 2 3 4
1a64EwBZYyvWzRyJSp4riV7moF0hmSWf5JY7XRIjJaWvnMpi6gKqz0BebqEAiHQN
