z31maniac
z31maniac PowerDork
3/7/13 6:47 p.m.
You guys may remember me asking a few days ago if there was an easy way to get the timing on my '90 Miata back to stock (10° BTDC).
Finally borrowed a timing light from a friend to fix it this evening.
drum roll
It appears on reassembly we had moved the CAS to 3-4° AFTER TDC.
Bumped it up to 12-13 BTDC, car is running MUCH better!
Toyman01
Toyman01 GRM+ Memberand PowerDork
3/7/13 7:02 p.m.
3-4 after sounds like a good way to melt something down. I'm betting the manifold was glowing.
Glad you found it. Things like that are always a huge relief to me. I always see dollar signs until the problem is found.
corytate
corytate SuperDork
3/7/13 7:36 p.m.
we had some trouble adjusting the timing on my buddy's NA, screwed up somehow and got it a couple degrees ATDC like you did.
It was amazing how badly it was running=] lol.
Luckily caught it and figured out why the CAS wasn't changing the timing when we turned it like it should have: jumper lead was unplugged. lol
z31maniac
z31maniac PowerDork
3/8/13 6:46 a.m.
Toyman01 wrote: 3-4 after sounds like a good way to melt something down. I'm betting the manifold was glowing. Glad you found it. Things like that are always a huge relief to me. I always see dollar signs until the problem is found.
Possibly! But it's an aftermarket header with header wrap.
I'm hoping I didn't hurt something on the drive home with that timing. Seems to be running good now, oil/coolant are good, but it seems AWFULLY noisy on startup. I know the 1.6s have a reputation for being a noisy in a "OMG is the engine falling apart" kind of way............but this seems worse than before?
I don't know. I guess I need to check to see if the crank pulley is wobbley.
It did drive just fine on the way to work this morning.
Alan Cesar
Alan Cesar Associate Editor
3/8/13 7:21 a.m.
Tick tick tick noise or something else?
A trick I learned from a Spec Miata guy recently: turn the CAS until you see just a sliver of a moon through the adjustment slot. That should be about 13 degrees BTDC. I checked with a timing light and it was spot on. You'll want to double check with a timing light as soon as you're able, but at least that would put you in a safe ballpark.
foxtrapper
foxtrapper PowerDork
3/8/13 7:29 a.m.
I really don't understand why the Miata crowd finds this all so fascinating/complex/difficult. It's essentially still a distributor, and you rotate it to change the timing.
If you want to get all fancy-pants, use a punch and mark it for the various settings, like 10, 12, and 14 degrees. Then you can adjust it spot on in mere seconds.
z31maniac
z31maniac PowerDork
3/8/13 1:42 p.m.
^It was just that we accidentally wiped off the mark for reinstallation.
Not that its so amazing.
Matt B
Matt B Dork
3/8/13 2:56 p.m.
z31maniac wrote: ^It was just that we accidentally wiped off the mark for reinstallation. Not that its so amazing.
I did the same thing recently. The integra had a nasty oil leak coming from the dizzy o-ring. So, I carefully marked the distributor position because I didn't have a timing light and as soon as it was off the car I proceeded to wipe off said mark during the cleaning process. Doh!
Now I own a timing light.
DaveEstey
DaveEstey SuperDork
3/8/13 2:59 p.m.
When I changed the CAS o-ring I used a scribe to make an indelible line.
One of the few times I've been smart in the garage.
QwdOq4aipI2xfpKSjDLp4A1SBwlurD9RPBRqCwB0WMDwtV8CDtKy78dwjamlMj4Y
