1 ... 3 4 5
Floating Doc (Forum Supporter) GRM+ Memberand UberDork
9/29/20 10:42 p.m.
Curtis73 (Forum Supporter) said:
Has anyone mentioned Slant 6?  It should be on someone's list.
You, me, donebrokeit, tuna55, probably more...
Certainly an iconic engine.
I had three of them in my first two cars. My first car, a 60 Plymouth suburban wagon was the first year of production of the slant six. My dad had a van from about the last year.
ShawnG
ShawnG UltimaDork
9/29/20 10:51 p.m.
Let's keep it to car engines.
This place gets a bit silly at times.
barefootskater
barefootskater UltraDork
9/30/20 12:37 a.m.
In reply to ShawnG :
"On second thought, let's not go to Camelot. 'Tis a silly place."
9/30/20 8:34 a.m.
Toyman01 (Moderately Supportive Dude) said:
In reply to pilotbraden :
If we are going to open it up to non car engines I would like to add the Detroit 12/71. That sound...
That's totally badass. Full pull.
I don't have much experience with diesels at all, but that thing is revving. It sounds like he's hitting at least 5,000.
Take a guess. What RPM is that running?
93EXCivic
93EXCivic MegaDork
9/30/20 9:01 a.m.
Honda B-series
Honda K-series
Honda D-series
Nissan RB
Toyota 2JZ
In reply to Floating Doc (Forum Supporter) :
Probably more like 2500 to 3000. But it's a 2 stroke so it fires every cylinder every revolution instead of every other.
I use to live about a mile from a fishing dock. There was a 110' head boat called the Thunder Star that had 3 12v71s. I loved listening to that thing leave the harbor at 4 am. The captain would get them synchronized and they would sound like someone was ripping down the gates of hell.
Placemotorsports
Placemotorsports Reader
9/30/20 9:04 a.m.
Toyota 4.7 2UZ-FE
Audi 3.0t
djsilver (Forum Supporter)
djsilver (Forum Supporter) Reader
9/30/20 9:41 a.m.
In reply to Toyman01 (Moderately Supportive Dude) :
And for those that don't know about Detroit Diesels, 12V71 means 12 cylinders at 71 cubic inches per cylinder, so 852 cubic inches.  The air enters the cylinder through conventional valves in the head, but leave through exhaust ports in the sides of the cylinders.
As the piston rises from the bottom, it covers the exhaust ports and starts compressing the air.
As it nears top-dead-center fuel is injected, starting the power stroke on the way down.
On the way down, the intake valves open and the turbochargers/superchargers push air into the cylinder and flush out the exhaust gases as the pistons uncover the exhaust ports.
I witnessed an air compressor with a 12V71, equipped with a supercharger and 2 turbochargers driving an air compressor that could move 1800cfm and 135psi.
https://en.wikipedia.org/wiki/Detroit_Diesel
solfly
solfly Dork
9/30/20 2:26 p.m.
Honda D, B, K, J
SBC
malibuguy
malibuguy GRM+ Memberand Reader
9/30/20 6:01 p.m.
Toyota Uzi
Mopar 3.3 V6
Toyota 5efe
Toyota 1nzfe
Chevy SBC
noddaz
noddaz GRM+ Memberand UltraDork
10/1/20 9:09 p.m.
Overall?   Or is this going to be broken down by generation?
Briggs & Stratton single cylinder.  Millions and millions and millions served.  Used old technology longer than most car companies.
Rolls Royce Merlin.  27 liters of flying power since 1933.
Ford Flathead, not because it was first or best, but because it was V8 power for the masses.
GM LS.  It probably has already been swapped into more cars than the small block Chevy.
And for my last choice I am going to lump one type of engine together.  AFAIK no matter who made them this engine layout survived years of neglect, years of abuse, adjust valves? Nah.  Let them tap.  Poor design from the manufacturer with the intake cast with the head, turbochargers, superchargers, lugging at low rpm, revving too high, run hot in stock form?  Bah, keep on going. 1 carb, 2 carb, 3 carb or fuel injection and these engines managed to soldier on.   I give you for my last choice, the straight 6 in all it's forms.
chgrec
chgrec GRM+ Memberand New Reader
10/2/20 7:42 a.m.
Alfa 2000
Jag 3.8
BMW S52
BMC B-series
VW flat 4
dean1484
dean1484 MegaDork
10/2/20 8:48 a.m.
In the top five that interest me but not necessarily good engines would have to include the Miller cycle K motor from Mazda.  I went down the rabbit hole a while back and found it is an amazing piece of engineering. The  block and head design have some little things that set it apart from other K series motors.  One of several motors I wanted to modify and build up with out having a car to put it in.
buzzboy
buzzboy Dork
10/2/20 12:46 p.m.
I think you've got your airflow backwards. The valves are exhaust valves and the intake is the 2stroke style ports in the cylinder walls.
The detroit has two of my favorite engine nicknames in the Screamin' Jimmy and the Buzzin' Dozen.
Carbon (Forum Supporter)
Carbon (Forum Supporter) UltraDork
10/3/20 9:26 a.m.
1/2jz
ls
k series
Hyabusa
testretta (Ducati)
DaveEstey
DaveEstey PowerDork
10/3/20 11:45 a.m.
Suzuki 1300 (Hayabusa)
Yamaha 3.2 V6
Chevy SBC
BMW M52
Pratt & Whitney Wasp
A 401 CJ
A 401 CJ GRM+ Memberand Dork
10/4/20 2:24 p.m.
On the water they get 450 hp out of half that V12.  6 X 71 or 426 cu in.  Those boat injectors burn too much fuel to stay cool on land though.  So you’re looking at about 350 tops for the 6 cylinder.  700 for the one in the Deere.  That’s with turbo of course.  The roots blower is a scavenge pump and it is considered NA with just the roots.  It will not run at all minus the roots blower.
Yourself
Yourself New Reader
10/6/20 12:40 p.m.
Any DOHC with DCOE's.
Ian F (Forum Supporter)
10/13/20 5:06 p.m.
In no particular order...
1. As sacrilegious as it will be to the brand faithful, I tend to lump all American OHV V8 engines together.
2. VW ALH
3. Cummins 12V 6BT
4. Triumph 6
5. Volvo B20
DirtyBird222
DirtyBird222 UberDork
10/13/20 5:31 p.m.
I'm going to base mine purely on the noises they make vs any other argument.
I'm a sucker for:
- Subaru EJs
- Audi/Lambo V10s
- Mercedes x63 V8s (n/a or twin turbo variants sound great uncorked)
- Intake noises from any Honda DOHC with a proper intake.
- Judd V10s
Opti
Opti Dork
10/13/20 6:34 p.m.
In reply to Ranger50 :
Is that a 3 valve under 4age....ewww gross
svxsti
svxsti Reader
11/15/20 9:24 p.m.
The Nissan VQ35DE/ Renault V4Y found in these:
Model Years Produced
North American
Nissan Pathfinder 2001–2004
Nissan Pathfinder 2012–
Infiniti QX4 2000–2004
Infiniti I35 2001–2004
Nissan Altima 2001–
Nissan Maxima 2001–
Nissan 350Z 2002–2006
Infiniti G35 Coupe 2002–2007
Infiniti G35 Sedan 2002–2006
Infiniti FX35 2002–2008
Nissan Murano (Z50) 2002–
Nissan Quest 2003–2016
Infiniti M35 2004–2008
Infiniti JX35 2012–2013
Infiniti QX60 2013–2016
Japan and other markets
Nissan Elgrand 2000–
Nissan Stagea 2001–2007
Renault Vel Satis 2001–2009
Nissan Skyline (V35) 2002–2007
Nissan Teana/Cefiro (350JM-J31) 2003–
Nissan Presage 2003–2009
Renault Espace 2003–
Tatuus Formula V6 2003–2004
Formula Renault V6 Eurocup 2003–2004
Nissan Fuga 350 GT 2004–2007
Nismo Fairlady Z S-Tune GT 2005–2006
Dallara T05 2005–2007
Renault Samsung SM7 2006–
Renault Laguna Coupé 2008–
Dallara T08 2008–2011
Renault Latitude 2010–
Dallara T12 2012–
Why? They can sound like this........ https://www.youtube.com/watch?v=E4L4Pfk9MlA&t=2s
1 ... 3 4 5
VmeL3SGEf4M6tie8BibuxjXSss7jF1msIjpkIcTFSWSXa4zrInlJ33U5IjCxw6wf
