You start by making the plug, The Heinkel Trojan/Kabine shaped object out of plywood and filler, then you make the mold from the plug, then you can pull parts from the mold.
The problem with composites is that you have to essentially build the part 3 times by the time you have one piece to work with.
I do quite like the idea of a Trojan/Kabine roadster. Isetta type cars are fishbowls and any sunlight is punishing
I'm assuming you want to DIY? I'm also assuming you don't have the original?
Make a pattern. Start with a bunch of styrofoam blocks glued together. If you have an eye for copying it's straight forward. But even if not you can make cardboard cutouts to transfer one side to the other.
If really no skill along those lines. Use a projector to display the pattern onto the foam blocks and cut away excess foam.
Once it's roughly in shape. Spread a layer of bondo on and smooth it out. Double check your work with the projector.
Trents right you make the part 3 times but basically it's just laying fiberglass over the pattern. Then relaying the fiberglass in side the mold.
There is a bit more. You need a release agent ( PVA is my choice) and gel coat. The pattern you can cheap out by using Fiberglass Matt. The part you can use matte or cloth. Cloth will be stronger.
There are plenty of examples on U Tube. But there are some tricks to make it less messy.
Oops! I see you are thinking of a production run, not a 1 off. Forget about splash molds and plan on using plywood for edging. If high numbers planned use aluminum or even steel. The mold will be a lot thicker as well.
I was actually asking about contracting with someone to build the body (and I would do the assembly)
DIY is not impossible
Contact these people.
http://cuttingedgecomposites.org/index.html
They can probably help you out but I bet it won't be cheap.
You could also try Jim Simpson and see if this floats his boat. Composite folks can be a little squirrely to deal with overall in my experience.
If you can create a 3D model of what you want, that might open up some options.
Is there a standard golf cart wheelbase and width ?
Are you planning on making them to sell , or have a fleet to rent out at the races !
Keith Tanner said:New business idea: SendCutSend, but for composite body parts.
With 3D scanning reaching hobbyist availability, and with 3D printing at large scale possible, I see this in the near future. I'm working on learning metal shaping skills just as they go (even more) obsolete..
frenchyd said:I'm assuming you want to DIY? I'm also assuming you don't have the original?
If you use styrofoam be careful what resin you use. Polyesther will melt styrofoam but you van use epoxy resin.
What I'm using on the Fmod is a material called Divinycell. It comes in blocks or sheets and can be formed with a heat gun and edge glued with Gorilla Glue. It can also be used with any resin and fabric.
californiamilleghia said:Is there a standard golf cart wheelbase and width ?
My friend wants one for her golf cart community (until she learned the price), and I figure it would probably be possible to sell them in small production runs in a town that has over 10,000 golf carts
Kendall Frederick said:Keith Tanner said:New business idea: SendCutSend, but for composite body parts.
I don't know if it would be better to print the plug or CNC mill it. I'll bet the latter would be a whole lot faster, and large format mills are more common than large format printers. But definitely the hobbyist ability to generate models has improved considerably.
Fun reading.
https://diyblog.commonfibers.com/blogs/process
Contact jmc14.
He's done an abarth sp1000 sports racer and his cheetah roadster thing. I think he works with a fiberglass company to have the bodies built.
Fair enough. I think a professional fiberglass shop could do what you are asking. Do you have any of those around you?
I know there are some in California and We have one here that does the hot rod air scoops, Bucket T' bodies, race car bodies, etc. But the time required would be about the same as you doing it yourself plus whatever time it takes to fit in their schedule. Oh and shipping. Plus they need to not only be paid for their time but a profit on top.
As estimate is going to have a good deal of padding since they have no experience with you as a customer. Something that can be a breeze or a night mare.
I'm optimistic but I suspect The younger me could do the pattern in a 24/ hr weekend. And have the mold ready by the following weekend. ( probably 12 hr. ).
I'd know how to avoid reverse drafts or if required how to deal with them. ( that's what traps parts in a mold) I'd also plan on using a light Matt material and make what's called a splash mold. Since I'd only make one part out of it.
There are short cuts like trimming the edges when the fiberglass turns leathery using a sharp utility blade rather than waiting until everything gets hard and creating an itchy dust storm of fiberglass using a cut off wheel.
If you want I'll walk you through the process.
triumph7 said:frenchyd said:I'm assuming you want to DIY? I'm also assuming you don't have the original?
There are plenty of examples on U Tube. But there are some tricks to make it less messy.If you use styrofoam be careful what resin you use. Polyesther will melt styrofoam but you van use epoxy resin.
That's why you cover the foam with Bondo. Once the pattern is ready then spray with PVA ( from your fiberglass supplier) and to ensure a quick release I use a good paste wax.
Yeh, it's overkill but I've never had a part stuck in a mold.
I'd be really curious what kind of numbers you might get for a whole body like that.
I looked into having a custom hood reproduced a decade ago. The shop I checked with wanted like $10k for molds and then $150-200 per piece produced.
Robbie (Forum Supporter) said:Contact jmc14.
..... abarth sp1000 sports racer..........
End thread.
In reply to Keith Tanner :
Nobody wants to pay what it actually costs....
I know guys that do both 3d printed plugs (they have a 4'x4' 3d printer) as well as CNC'd foam stuff. They make all sorts of CF panels for vintage cars, race cars, street rods, OE'S, etc.
Problem is for one off stuff, it's so labor intensive that most people have a grabber when they get the quotes. You know as well as anybody the price only comes down in scaling up. And for one off parts...that's hard. When this guy wants a set of CF door skins for say a Studebaker for Bonneville, and then maybe 8 years from now you will get another order. In the meantime you're left storing those molds properly. Or they go to E36 M3, fast.
I've been following a Canadian guy on YouTube: https://www.youtube.com/@ThrottleStopGarage He's been making carbon fiber body panels for his Volvo 122, and goes into great detail about the process.
Or, you could follow the methods of Ed 'Big Daddy' Roth who built a series of wild custom cars over a period from the 1950s through the 1980s - he'd build a buck using wadded up newspaper and plaster of Paris, cover it with fiberglass, and then knock out the plaster with a sledgehammer. It was a dirty, time consuming process, but it was cheap.
You may want to look into vacuum-forming sheet plastic rather than FG molding, with this process once the mold is made, you can have a machine stamp out panels in minutes rather than being painstakingly handcrafted over a days-long process, and you can get similar-looking results, possibly with no need for paint.
Edit: Video:
GaryC83 said:In reply to Keith Tanner :
No argument here. I'm working with some custom circuit boards right now, and the per-cost price for 50 is an order of magnitude less than the per-cost price for 1. It's all about the initial and there's no way around that.
But maybe we can take advantage of improved low-volume manufacturing tech to bring down the cost of that initial tech. It's never going to be cheap, but it would be interesting to take a look. We're getting some castings done, and 3D printing has helped bring the cost that down enough that one-off prototypes are plausible. Small run injection molding is less expensive than it used to be as well. Can we use big CNC mills to make a plug, or maybe even the mold directly? Spray chopped 'glass into it and trim? I guess a large part of it depends on the finish level expected.
Keith Tanner said:GaryC83 said:In reply to Keith Tanner :
To answer the question above, yes.
These guys use a big gantry style 5 axis CNC to create the plugs to recreate the Talbot Lago molds.
https://tlccar.com/
The most difficult part is finding someone to lend you the original to scan, or making the cad drawing.
A great place to look for help is the boat industry. No one has more experience when it comes to fiberglass and molds.
I dont have any contacts, but here in the Ft Lauderdale area there are tons of boat building and hull repair shops.
