motomad1
motomad1 New Reader
4/10/12 6:42 p.m.
I've come across a 1995 Mercedes E320 Station Wagon: strong engine, no rust, immaculate interior, 150K miles according to listing. Son is selling for parents, yeah I know, Brooklyn Bridge. Complete photo detail. Nice.
Reverse (auto trans) does not work. Listed at $1,650. I could probably drive it home as long as I don't have to parallel park.
What say the GRM cognoscenti. Is this a money pit or an easy fix? Keep in mind, I am not mechanically inclined and it would go to a mechanic. I'm really liking this car.
Consider or run away?
chandlerGTi
chandlerGTi HalfDork
4/10/12 7:01 p.m.
Pretty normal on those trans. Expensive to replace but plentiful in junkyards. I would buy one for that.
bgkast
bgkast New Reader
4/10/12 7:03 p.m.
Google "biodegradable wiring harness"
DrBoost
DrBoost UberDork
4/10/12 7:31 p.m.
bgkast wrote: Google "biodegradable wiring harness"
Yeah, I think that one could have it. Expect to pay half the asking price to replace the wiring.
ccrelan
ccrelan Reader
4/10/12 8:03 p.m.
It is very easy to check the wiring harness. There is a plastic panel that comes out right behind the battery. Feel the harness and check the tag for a date.
Check to make sure the AC works as it is expensive to fix as well. Definitely look inside the coolant reservoir to make sure there isn't any oil in the coolant. If the engine is a leaking on the outside, it is a sign the head gasket is on its way out. Very common issue with the M104.
These are great cars, but you really have to check for these handful of things.
93EXCivic
93EXCivic UltimaDork
4/10/12 8:54 p.m.
Run away.
carzan
carzan HalfDork
4/10/12 9:26 p.m.
As the owner of a W124 Mercedes, if you are not mechanically inclined, I would advise against buying it. They are typically good cars, but can be expensive to keep if you have to depend on a shop.
The biodegradable wiring included cars built between 1991 and 1996, so this car could be affected. If you have to have a shop replace the harness, you are likely looking at at least $1000.
The transmission is bad and it could run over $1000 for that, too. No telling what else is going to need attention on a 17 y.o. car. Again, I'd advise against it.
0mtAZfX3QPTeYxkdg93ft01iXmikY9TtKtciDDy430fw4HWDVMO8UmRcX5r8WYvM
