Giant Purple Snorklewacker wrote: Same old trick... probably applies here. Move the piston to the bottom of it's travel and fill the cylinder with shaving cream in case you are grinding bits of metal or porcelain with the EZ out. When done... turn the motor to push it out.
I understand the purpose of the shaving cream and the piston being at the bottom of it's travel … but how do you get the shaving cream into the combustion chamber if the spark plug is still in the hole ?
