SkinnyG
SkinnyG Dork
11/25/14 9:29 p.m.
Actually two of them. What say you?
Clickie the Linkie to Biggie Size it.
Giant Purple Snorklewacker
11/25/14 9:33 p.m.
By "gasket(s)" do you mean "dude(s)"?
Also the parts in that picture appear as if they have been breached.
Toyman01
Toyman01 GRM+ Memberand UltimaDork
11/25/14 9:33 p.m.
I would concur. I would say it might be time for some quality studs.
Hungary Bill
Hungary Bill GRM+ Memberand Dork
11/25/14 10:12 p.m.
SkinnyG
SkinnyG Dork
11/25/14 10:22 p.m.
So.....
I have already put it back together with new gaskets. Can I still swap in some studs one at a time, or do I need to pull the heads off and do it again?
(or just wait six more months, and do it then....)
Streetwiseguy PowerDork
11/26/14 6:54 a.m.
Hope you planed the heads.
trucke
trucke HalfDork
11/26/14 7:44 a.m.
Hungary Bill wrote:
Oh my! I've seen that recent news story, but it's too graphic to post a link here.
pinchvalve
11/26/14 7:48 a.m.
Here's how bad my cars have been: that doesn't look to bad. There are no tears between cylinders...I mean you can still identify 8 distinct holes.
Bobzilla
Bobzilla PowerDork
11/26/14 8:45 a.m.
In reply to pinchvalve:
Yeah, I was gonna say that's not too bad. Sure... they are leaking but its still THERE.The ones that came off the vette.... well that was another story.
dinger
dinger Reader
11/26/14 8:57 a.m.
SkinnyG wrote: So..... I have already put it back together with new gaskets. Can I still swap in some studs one at a time, or do I need to pull the heads off and do it again? (or just wait six more months, and do it then....)
You can do studs one at a time.
The_Jed
The_Jed UltraDork
11/26/14 9:00 a.m.
Where's the fun in that?
Did these gaskets come out of your Silverado?
SkinnyG
SkinnyG Dork
11/26/14 9:32 a.m.
Aye, they did. Excessive white, lingering, exhaust. Cannot keep coolant in rad and it does not get drawn back from overflow (I've checked and replaced the cap, inspected for leaks/cracks elsewhere, nothing). I noticed after fueling it up on Monday, on restart there was quite a LOT of white smoke. So - Monday night I pulled the heads and did the gaskets again.
SkinnyG
SkinnyG Dork
11/26/14 11:41 p.m.
Things seem a lot better. Coolant level seems a bit happier, but I'll check and see tomorrow morning how it did today. It certainly is no longer blowing coolant out the overflow. I'm guessing the heads are probably not cracked, otherwise I would not see improvement.
I had pulled this apart right after supper on Monday, and had it back together and running by 4am. Needed the truck to get to work...
I ordered head studs this morning on the way in.
True - at least the head gaskets are still ~there~, but I already suspected it was a problem. No need to wait until it was the coffee milk goodness of death.
Knurled
11/27/14 8:23 a.m.
pinchvalve wrote: Here's how bad my cars have been: that doesn't look to bad. There are no tears between cylinders...I mean you can still identify 8 distinct holes.
I like the turbo Buicks that blow the gasket out with a chunk so big that it stays lodged between the pushrods and the block.
Odd that it's never on the exhaust side. It's almost as if detonation occurs far away from the spark plug, where the heat and compression of the expanding flamefront cause the end gases to spontaneously explode.
2uIeLi5XPIIF62T3kgp1PHGoiUd7oiCwQxlGn1YffMYnT6dam9qwIaa67sYozyYj
