chknhwk
chknhwk Reader
12/31/08 7:56 a.m.
Looks like the crack goes all the way through and around. It has also been throwing intermittent cel's - haven't been able to capture one yet.
Sorry for the crappy cell phone pic...
Tyler H
Tyler H GRM+ Memberand Dork
12/31/08 8:06 a.m.
Well...its not good.
I'd replace it just for good measure. If it is rare, then it could maybe be welded up. Otherwise, not worth the hassle.
Might want to check your motor mounts. Does your exhaust have a flex section?
chknhwk
chknhwk Reader
12/31/08 8:12 a.m.
I'll take a look at the motor mounts. I'm pretty sure it has a flex section, I haven't really fiddled around with this car much. And it's DEFINITELY not rare, unless you consider a '98 Hyundai Accent rare. LOL Has anybody seen anything on header fixes? I really don't have access to a welder right now...
Strizzo
Strizzo Dork
12/31/08 9:08 a.m.
i worked with a guy at autozone that had a 98 accent that developed a crack in the manifold like that. it would throw lean codes because the leak was letting in air and throwing off the O2 sensor
44Dwarf
44Dwarf Reader
12/31/08 9:22 a.m.
If $$ are tight...try this hack. Go to a good hardware store get a can of furnace cement. wire bush the manifold then start the motor for 30 sec or so just to warm it not hot just warm. Then pack a 1/4 to 1/2 thick layer around the crack going at least 3/4 of and inch on each side. Leave over night then warm it up a few minutes and let cool a few times. You'd be surprised how long it last. Worked great on my integral intake exhaust manifold on a 6 cyl 5years.....
44 had a new manifold after 2 months but it was working so ..
JThw8
JThw8 Dork
12/31/08 10:09 a.m.
chknhwk wrote: unless you consider a '98 Hyundai Accent rare. LOL
That explains it, seems to be a common issue with that era of Hyundai. My dad's 99 ate 2 exhaust manifolds in its lifetime (120k)
chknhwk
chknhwk Reader
12/31/08 5:17 p.m.
Furnace cement, huh? I think that's what I was looking for! Thanks.
Tyler H
12/31/08 6:00 p.m.
I got a can I'll send you for the cost of shipping. ;)
chknhwk
chknhwk Reader
12/31/08 8:50 p.m.
Hmmm, I might have to think about that. I'll let you know if I can't find anything.
dean1484
dean1484 GRM+ Memberand HalfDork
12/31/08 10:39 p.m.
FYI Welding of cast is a PITA. You have to beat the crap out of it with a hammer before welding as well as add alot of heat to it (rosebud torch works well for that). Get another if you can (eBay, junk yard etc.) You will probably pay less for it than the cost to have it welded properly. I really like the furnace cement!! That is a great idea. I may have to try that in my truck soon as it is starting to leak. I am hoping it is a gasket.
chknhwk
chknhwk Reader
12/31/08 11:37 p.m.
I know some of the 4g63t manifolds fit up but I'm not sure I want to go down that path right now... If I could sell my bmw I probably would.
HIrhYhm4iSaaobiXxgDNxj8ThlECp6AJfy704P098gGGeEdXW2sGmLXqKl1J4k4m
