budget_bandit
budget_bandit Reader
8/18/24 12:13 p.m.
I'm swapping a 5.3 truck engine into a car from the 70's. Do I need to have an evap system? I know the engine will run without one, but will my garage smell like gasoline?
I'm going to use a fuel sending unit from an LS1 camaro, which has a vent line and an evap line. Should I just get all the original camaro evap components and use those, or is there a better option?
Streetwiseguy MegaDork
8/18/24 12:28 p.m.
It's not that tough to transfer the stock stuff over.
I kept it with the 6.0 in my 67 Camaro.  Finding a home for the stock charcoal cannister was tough, and I am using an aftermarket tank that does not vent super well when filling the tank.
Getting the gas cap to seal is an issue for a 67, but if it's behind a door, you can adapt a proper gas cap.
Having said that, no real benefit other than gasoline odors.
rustomatic
rustomatic HalfDork
8/19/24 8:00 p.m.
The answer is yes and no.  If the hook up of the LS1 stuff is easy, do it, as your garage will smell like a gas pump otherwise.  That said, there are other ways of fixing this, like with an old-school paper filter (like VW Bug), a catch can, and some other creative stink-stopping efforts that slow the flow of gas (not in the gasoline sense, but in the makes fire/farts sense).  Aim for at least a -8 equivalent breather line.  Summer months provide a fun test.
8/19/24 9:13 p.m.
I like having working evap systems for cars that sit often, because the fuel stays fresh in the tank.
A sending unit for an LS1 Camaro may include the pressure sensor.  If so, all you will need for it to work correctly is the canister and a vent solenoid, as the purge solenoid should be packaged directly on the engine.
You may also need a different type of fuel cap.
budget_bandit
8/21/24 7:12 a.m.
I appreciate the feedback, folks. My 5.3 ostensibly came complete, so as long as it's not wildly expensive to obtain the other camaro parts, i'll try that
cyow5
cyow5 Reader
8/21/24 8:00 a.m.
Funny enough, I used a GM evap solenoid to replace the faulty one on my Elise. Super cheap.
budget_bandit
8/21/24 9:04 a.m.
In reply to cyow5 :
I love to hear it
VIADi2dSdzZNnUBEmy89zT62z8M7pbqZP3y50DIY7uTZFNPiGyqETDXog9gHxqVa
