glueguy
glueguy GRM+ Memberand Reader
6/22/12 3:21 p.m.
doing a catback exhaust on an older car. Which is more likely to give success and not snap an exhaust stud - conventional socket by hand or an impact gun?
z31maniac
z31maniac UberDork
6/22/12 3:32 p.m.
Either way, I spend a few days soaking them with penetrating oil.
NGTD
NGTD Dork
6/22/12 3:37 p.m.
I would say impact - but I just assume they are going to break. I have almost never taken an exhaust system apart without breaking them.
Salt and heat are a great combination
92CelicaHalfTrac
92CelicaHalfTrac MegaDork
6/22/12 3:44 p.m.
I've never broken one, but i do tend to make a LOT of "Snuts" or "Stolts."
m4ff3w
m4ff3w GRM+ Memberand UltraDork
6/22/12 3:45 p.m.
92CelicaHalfTrac wrote: I've never broken one, but i do tend to make a LOT of "Snuts" or "Stolts."
I've had one break. I use lots of PB Blaster.
ansonivan
ansonivan Dork
6/22/12 3:46 p.m.
Loosen by hand with oil, heat and a few sharp hammer blows on the end of each fastener via the socket. With the impact you stand no chance of backing off if the fastener is shearing, a well calibrated hand can make multiple attempts with increasingly drastic heat/impact between torque applications.
All hail the hand.
heyduard
heyduard Reader
6/22/12 4:06 p.m.
by hand.
I snapped a stud with an impact driver by being trigger happy.
dean1484
dean1484 UltraDork
6/22/12 4:15 p.m.
Apply heat!!!! Get it red and the bolts will usually come off with out damage to the studs (Map Gas Tourch is your friend)
Knurled
Knurled GRM+ Memberand Dork
6/22/12 4:59 p.m.
Heat it orange first.
Or, my method - just break it, if it's weak enough to break then it doesn't deserve to be on the car.
motomoron
motomoron Dork
6/22/12 6:23 p.m.
Heat, Kroil, let cool.
Next day: Heat, Kroil, whack the nut w/ a drift and a hammer while it's hot, 6-point socket on hex, 12 point on 12 point nuts, breaker bar, off.
HappyAndy
HappyAndy Dork
6/22/12 6:30 p.m.
Knurled wrote: Heat it orange first. Or, my method - just break it, if it's weak enough to break then it doesn't deserve to be on the car.
QFT on both statements.
93gsxturbo
93gsxturbo HalfDork
6/22/12 6:30 p.m.
If the bolts are even somewhat accessible, I will usually hit them with PB a few days before I need to take them off while the engine is hot from a drive and let them cool.
Wire brush the threads before removing and work the nuts back and forth by hand if they jam up.
Woody
Woody GRM+ Memberand UltimaDork
6/22/12 7:30 p.m.
motomoron wrote: Heat, Kroil, let cool. Next day: Heat, Kroil, whack the nut w/ a drift and a hammer while it's hot, 6-point socket on hex, 12 point on 12 point nuts, breaker bar, off.
Heat and Kroil is my favorite combo, but I like the drift whack idea. I'll have to give that a try next time I'm cursed with an exhaust replacement.
Kenny_McCormic
Kenny_McCormic New Reader
6/22/12 11:40 p.m.
They spin right off with hand tools if you get them glowing red.
Aeromoto
Aeromoto Reader
6/22/12 11:49 p.m.
By hand with PB Blaster and luck
calteg
calteg Reader
6/22/12 11:52 p.m.
93gsxturbo wrote: work the nuts back and forth by hand if they jam up.
Really? Tell me more, like your phone number for instance
DPQiNnRAOabxsQenPkPNHdNXbinsp5RkOoLhN2ebqAgEcGCFtMEzcOrmpUyKW3QJ
