This is the first year where I'm met with the combination of a soft top, roll bar and hard top. As I get ready to install the hard top for the Winter, I'm concerned abut ruining the plastic rear window while its folded up for the season. Before the roll bar, I used one of hose window protectors when the top was down. That's no longer an option.
On my last car, I solved this by removing the soft top all together.
Any suggestions for caring for the window?
Sultan
New Reader
11/29/09 11:17 a.m.
I took a foam tube cut it to length and wrapped it in a clean towel so the plastic wouldn't stick to the window. The foam tube keeps the window from creating a line in the plastic. The foam tube was what my kids call a noodle from the pool but I’m sure a pipe insulator would work as well.
+1
I used to do this in my '97 that had a rollbar installed and it worked great. The one time I decided to be lazy and not use it was on a cold day when I was autocrossing...I threw the top back and sure enough it was cold enough to crack the plastic window all the way across
Since the top will be down for the whole season, you may want to tuck a towel around the inside part of the fold as well.
kcbhiw
Reader
11/29/09 11:14 p.m.
I'll hand off another +1 to this. Works quite well.
car39
Reader
11/30/09 8:07 a.m.
One of the Miata suppliers sells a cushion for this. I've used it on the 3 Miata's I've had, it keeps the window from folding.
I just used to stick a rolled up towel in there. Easier to store than a pool noodle and more useful overall. I'm not sure it ever made a difference.
Any suggestions for protecting the inside?
Towel wrapped on both sides
