hotrodlarry
hotrodlarry New Reader
1/18/09 8:01 p.m.
A friend of mine found these pieces underneath their '89 VW Golf. They are pretty sure the parts came off the fuel distributor
Photobucket
any idea where they go?
doc_speeder
doc_speeder New Reader
1/18/09 10:01 p.m.
Is it a 16v or 8v? I'm pretty sure the '89 8v wouldn't have a fuel distributor, as it should have digifant II electronic injection. Other than that, I'm clueless, I've never had a CIS fuel distributor apart (in case it's a 16v).
Per Schroeder
Per Schroeder Technical Editor/Advertising Director
1/18/09 10:08 p.m.
Mmmm. My first thought would be something behind the frequency valve/fuel pressure release valve which manages fuel pressure (and therefore mixture) at the fuel distributor. It's on the side, perpendicular to the flow of air into the FD
edit: missed the part where it was on a digifunk.
dunno...any holes that need plugs under there? That looks a little like the oil pressure spring/cap/circlip on a Saab B engine that's on the external oil pump.
hotrodlarry
1/18/09 11:51 p.m.
I've had fuel dizzys apart, but on Saabs and I don't remember seeing anything like that on my '85 8v 900. Never messed with a VW before though.
edit: missed the part where it's probably a digifunk car.
So..dumb question. there's a cap, a circlip and a spring...is also any hole that is currently unoccupied in the engine compartment where this would all fit?
7pilot
7pilot New Reader
1/19/09 2:33 a.m.
If they came off the VW, then it would be the transaxle. It has been a while since I worked on any Golfs.
The pieces are too large to have come off the fuel distributor(16v only)
I don't think they are VW parts.
m
fornetti14
fornetti14 GRM+ Memberand New Reader
1/19/09 6:11 a.m.
That silver round piece looks like a La Castelette center cap at first glance. You might want to filp it over or show how thick it is. It also looks like a 8V lifter shim.
Strizzo
Strizzo Dork
1/19/09 10:29 a.m.
lol, did it just puke a valve spring?
hotrodlarry
1/19/09 7:49 p.m.
got it figured out...
Car is actually an '87.. and the parts don't belong to it. problem solved. thanks for the ideas/help.
ZsfOUh9FBNtfms2hAVOvCUX10cf8LLsktXEfKGhJGSzPVw57254KZSMwfMEPa9we
