Datsun240ZGuy
Datsun240ZGuy MegaDork
8/9/24 11:50 a.m.
I just went outside and set my 240Z on fire.......
classicJackets (FS)
classicJackets (FS) SuperDork
8/9/24 12:27 p.m.
In reply to Datsun240ZGuy :
I think mine would like to set me on fire.
MyMiatas
MyMiatas Dork
8/10/24 11:50 p.m.
That color sure beat the doo doo brown it was painted. IMO They painted it all at once in two booths so the color matched best. The shop lights are very impressive. Would they help with picking things out
stuart in mn
stuart in mn MegaDork
11/2/24 3:44 p.m.
Short update from My Mechanics.  He makes his own locknuts.  "I make a new one." smiley
Datsun240ZGuy
11/2/24 4:53 p.m.
Crazy
11/2/24 10:12 p.m.
Trent said:
In reply to j_tso :
I have no idea.  Around here the options are sand (usually not sand but a crushed glass or aluminum oxide media), soda or dry ice.
Of the cars that come in and get torn down, it is always sand.... and it is everywhere 20 or more years after the blasting took place.
I also don't believe the "walnut won't warp panels" thing. I'd say it is "less likely to". Even soda blasting will warp a panel if done poorly enough.  I have a W113 pagoda trunk lid anyone can inspect if they say otherwise.
Wouldn't the trapped media collect moisture and accelerate rust?
Trent
Trent UltimaDork
11/3/24 10:39 a.m.
In reply to Pete. (l33t FS) :
It sure does!
newold_m (Forum Supporter)
newold_m (Forum Supporter) Reader
12/13/24 9:10 a.m.
Ep6 is out
12/13/24 9:31 a.m.
"Ball joints are bent, I make a new one"
theruleslawyer
theruleslawyer HalfDork
12/13/24 10:01 a.m.
How did he resist taking a pressure washer to those parts before working on them? Ick.
stuart in mn
12/13/24 11:31 a.m.
His level of detail is crazy.  I mean, who makes their own ball joints.
One thing I'd disagree with him on is powder coating everything the same semi-gloss black...I think some parts should have had a cast iron look, others a plated look, etc.
06HHR (Forum Supporter)
06HHR (Forum Supporter) SuperDork
12/13/24 11:43 a.m.
I wish I had not opened this thread, I want to watch this right now but i'm at work and I actually have work I need to get done. Aaagh!
Datsun240ZGuy
12/13/24 11:50 a.m.
 He drilled out the spot welds on the two frame rails, removed the rails and hammered all the dents out, cleaned the rails and put them back onto the car.
Most buy new frame rails but he can say his Z has the original restored frame rails.
That blew my mind.
12/13/24 12:11 p.m.
He's driven by the joy of fixing things. Sure, it's easier to just bolt new stuff on but that is clearly not how this cat is wired. The ball joints were totally unnecessary but fascinating. So was chamfering every single seam on the subframe :)
And I'm only about half through...
j_tso
j_tso SuperDork
12/13/24 1:41 p.m.
makes his own ball joints and nylock nuts. They're available off the shelf, but doing this gets him clicks and helps pay for the restoration.
The steering rack rebuild was good. Those metal bushings would have been hard to source so his skills and tools saved it.
12/13/24 4:27 p.m.
In reply to j_tso :
I don't think it's just for the clicks. I think it's because it's more interesting to him and that's how he's wired. The effort that goes into his work is far higher than could be justified by video monetization. All of that filing speaks to more of a compulsion than profit.
DarkMonohue
DarkMonohue GRM+ Memberand SuperDork
12/13/24 10:17 p.m.
Alright, dangit, I'm in. Glad somebody brought this up here. I quit watching the channel because the fanatical over-restored aesthetic doesn't really work for me, but the Datsun does look like fun...
1/27/25 1:37 a.m.
Walnut blasting episode. Weirdly soothing to watch to get metal under the paint and crud exposed...
Piguin
Piguin Reader
1/27/25 3:24 a.m.
Meh.
Dude didn't even bother making his own grease nipples, just went and bought them. His lack of drive is heartbreaking.
/Sarcasm
Scotty Con Queso
Scotty Con Queso UltraDork
1/28/25 3:44 p.m.
After watch him do all that bodywork, I can say with confidence that I don't ever want to do that.
stuart in mn
1/28/25 8:17 p.m.
The last couple weeks he's also been posting some video shorts, with excerpts from previous long form videos.
3rcS5KLe9Nz66eusRKFuoHCgNqhkcGwGVQGYHWe5dlBZyBCKmYUjJWR9M2cRZf9Y
