RacingComputers
RacingComputers GRM+ Memberand Reader
9/27/23 9:59 a.m.
In reply to akylekoz :
Not certain the roads are wide enough to turn that train around/
Nice suggestion though
RacingComputers
9/27/23 10:05 a.m.
In reply to Mike (Forum Supporter) :
Thanks for the input
Odd is great within 200 miles of home (AAA towing range)
Parts availability for common stuff would seem to be prudent, as anything in the $12.5 K range more than likely will have major miles on it.
Ran the One Lap back in 1985
Choose the then NEW Bronco II with the V6 motor
Needed a lower radiator hose in the Death Valley area.
The only 6 Cylinder Ford part that was within 500 miles was for a 300 CI Straight 6
Lesson learned and remembered
Thanks
RacingComputers
9/27/23 10:08 a.m.
RacingComputers
9/27/23 1:43 p.m.
Cross Posted in Advrider motorcycle forum
Similiar input
Regards
californiamilleghia
californiamilleghia UberDork
9/27/23 3:57 p.m.
Is the  worst roads in Canada or once you cross the Alaska border ?
What do the Mounties use or Canadian road crews .
I would think the part that is most likely to fail is the Auto Trans ,  at least that's what I am always worried about .......
once you make your pick , start a thread on whatever spares to bring on a trip like that ,
Have fun :)
RacingComputers
9/27/23 4:57 p.m.
Thanks
Manual transmission and locked (posi) are two non negotiable "bits"
Thoughts the Canadian Mounties still rode Horses?
Good point though
There will be a FOLLOW ME THREAD
YRMV
RacingComputers
9/27/23 8:15 p.m.
The Adv rider motorcycle group is pushing   GMT800 or GMT900 based truck/SUV,
Need to dig a bit deeper
Thanks
pres589 (djronnebaum)
9/27/23 8:33 p.m.
Why would a bunch of motorcyclists suggest trucks?  Are motorcycles not on the options list?
RacingComputers
9/27/23 10:33 p.m.
Back back, gimp knee and ...............................................
Thus the 4 wheeled option
Guys on a motorcycle forum, don't ride, they just post.
Running joke over there for a long time
FWIW
Regards
9/27/23 10:46 p.m.
Sure.
AAZCD-Jon (Forum Supporter)
AAZCD-Jon (Forum Supporter) SuperDork
9/28/23 12:11 a.m.
Gen 2 Prius with a few 'overlander' mods. Seriously. I started searching and found quite a few stealth campers and some blogs like this:
http://rgkbjk.blogspot.com/?m=1
RacingComputers
9/28/23 9:50 a.m.
Thanks Jon
FIL has a Prius that might be going to be surplussed.
Will investigate
Thanks
Rons
Rons GRM+ Memberand Dork
9/28/23 12:15 p.m.
In reply to californiamilleghia :
Suburban RCMP mostly Explorers, some F150 SuperCrews, and F 350 4x4 Crew Cabs. The farther north and more remote would skew more to F 150, F 350.
RacingComputers
9/28/23 12:42 p.m.
Google Search Foo not that strong here
However, the Ford F Series makes sense.
Miata is always the answer for a Sporty Type car, why not the F Series.
Regards
bmw88rider
bmw88rider GRM+ Memberand UberDork
9/28/23 1:21 p.m.
Anymore there are a ton of SUVs that will make the trip. It's not a vehicle problem, It's a what do I want to sleep in problem and a can I fit enough gas in it problem. The second one shouldn't be an issue unless one of the stops doesn't have gas which isn't uncommon.
I'm sure you have seen this but a good guide to what is out there.  It's a 9K+ mile round trip so getting something a little more fuel efficient than a GMT800 may not be bad.
Dalton HWY guide
You want bug protection up there so if you do a pickup, price out a shell. Problem is, you aren't sleeping in most of the f-150s out there.
RacingComputers
9/28/23 1:32 p.m.
Only a One Way trip for the Vehicle
Will have accomodation for either a larger fuel tank or RotoPax Type container
Planning on Donating or Selling once I get back to Fairbanks
Appreciate the link
Toyman!
9/29/23 9:08 a.m.
This was bought for $2750. I spent a weekend doing maintenance and we put in on the road for 4000 miles up through Maine. Lots of gravel roads while exploring. It now has 340k on it and I'd climb in it tomorrow to drive to AK. They are as reliable as an anvil. So many vehicles were made that share the drivetrain that parts are cheap and available everywhere. This one is 4WD and does very well off-road as long as you keep the approach and departure angles in mind.  It's only downfall is going to be the fuel economy. 17 mpg is the best I've ever gotten and it's usually more like 15.5.
RacingComputers
9/29/23 11:51 a.m.
^^^^^^^^   Year range    Great Price Point
Thanks
RacingComputers
9/29/23 11:08 p.m.
Suggestion of search engine to locate a vehicle once the type hs been finalized?
Sonic
Sonic UberDork
9/30/23 12:07 a.m.
The vehicle toyman suggested is the GMT800 suburban, 2000-2006.  Agreed they are the most recent automotive cockroaches and will have the best parts availability anywhere in North America.  I've personally been involved in the maintenance of 2 of them
RacingComputers
9/30/23 7:12 a.m.
In reply to Sonic :
Thank you both for the input
The Adventure riders gang is high on Suburbans also
Might be the right approach.
Regards
RacerBoy75
RacerBoy75 Reader
9/30/23 2:46 p.m.
Don't think you'll be able to find a manual transmission Suburban easily...
RacingComputers
10/1/23 8:11 p.m.
Manual is not a "HAVE TO HAVE",but thank you
RacingComputers
10/3/23 5:01 p.m.
Mrs. Racing questioned the need of another vehicle
"Whey not drive the 2005 Mustang you already own
https://grassrootsmotorsports.com/forum/cars-sale/2005-mustang-gt-5-speed-53k-miles-mine/164582/page1/
It has a cage, good seats, no back seat, nothing in the trunk, tow hooks on both ends,
She suggested replacing the lowering springs with the stock SN197 Springs, installing stock (Narrower Wheel and tires, and just going for it.
Probably change the rear gears back to 3.27 or close, set alignment back to "Stock"
Camping out of the Mustang would be similar to what JamieZ did with the Miata, but hey, he is JamieZ.
Wheels and tires might be an interesting challenge
Parts should not be hard to locate as Ford made 2, 608, 814 and there are many many parts that are not SN197 Specific.
The Donation at the end of the trip thought might change the dynamic.
Thoughts and or input
TRMV
Mike (Forum Supporter) GRM+ Memberand UltraDork
10/3/23 9:55 p.m.
I mean, dang, that's a change of scope.
That said, it's a road.
There are a wide variety of Mustangs in the world, and at this age, a wide variety of conditions. If it's a particularly special car in particularly special condition, I would question whether you are putting that special condition in peril.
If this is just a clean daily or below, it sounds like you'd want to spend some time thinking about protective options and prep. Everything I've read warns of flying debris from passing trucks, managing fuel, tire punctures, and accidentally yeeting yourself from the right-of-way.
Protective might include paint film, mud flaps, and other things to protect from thrown rocks.
Prep might include one or more full sized spares, recovery gear, a tool set, gas cans and some way of carrying all of that, and maybe a CB and/or ham radio.
If this is your beloved Mustang, you're driving back, which ads to time off from $dayjob, or shipping back, which I'd $$.
I imagine it's not hard to find Mustang wheels and tires on Facebook Marketplace, or to sell them when you're done.
No shop along the way is going to be flummoxed when faced with a Mustang, and some stuff is likely to be in stock at the Oreilyzonebros.
None of what I'm saying is clever though. I've just been daydreaming this trip a bunch.
mhA3iMco4o0YnBUb7SjG9KiGbHeOU6rK6LwzleBKi8rJLxiz6iVr10Kjy8DIfrbx
