oldtin
oldtin UberDork
9/2/14 8:35 p.m.
Looking to lower the back end of the TR4 around an inch. Made up some spacers - Stock u-bolts don't fit for length. Axle tubes are 2.25. Stock u-bolts are 3/8s - 24, 2.25 x 5 (ish). No joy with McMaster, trailer axles and my google-fu is failing me. Any ideas? Clearances are tight. I might be able to make 1/2" bolts work... even then, not finding the right tangent length.
jamscal
jamscal Dork
9/2/14 8:50 p.m.
napa? I bought some in the past and the napa box had a list a mile long of the sizes they offered.
Several local frame/trailer shops bends/threads them to your specs, as well.
Ditchdigger
Ditchdigger UltraDork
9/2/14 8:55 p.m.
http://www.dsuban.com/Custom-U-Bolts-c72/
Here in Eugene I would send you to Brooks "cut rate auto parts". They have a huge wall of U-bolts and on the off chance they don't have what folks need there is a big truck/semi alignment shop that makes custom U-bolts in whatever dimensions you need for about $10 each.
Giant Purple Snorklewacker
9/2/14 8:57 p.m.
All-thread + torch?
oldtin
oldtin UberDork
9/2/14 9:14 p.m.
Ditchdigger wrote: http://www.dsuban.com/Custom-U-Bolts-c72/ Here in Eugene I would send you to Brooks "cut rate auto parts". They have a huge wall of U-bolts and on the off chance they don't have what folks need there is a big truck/semi alignment shop that makes custom U-bolts in whatever dimensions you need for about $10 each.
perfect - thanks!
curtis73
curtis73 GRM+ Memberand UberDork
9/3/14 12:08 a.m.
If you can't find them at fastenal.com, try redneck-trailer.com and then etrailer.com
jstand
jstand Reader
9/3/14 8:41 p.m.
Check with the local spring shop, many times they can custom bend ubolts.
beans
beans Dork
9/4/14 6:49 p.m.
jstand wrote: Check with the local spring shop, many times they can custom bend ubolts.
This. Just recently paid $55 for a set of four at Toledo spring. Had them within 5 minutes of walking through the door, made on the spot. Most places are open pretty late, too.
VJf8WiYVoQmTarjHQUdU1hBKtEzBY2nRieVh6bldQqbPcQAycQWfNSizgn1ktZdy
