ClemSparks
ClemSparks SuperDork
11/13/08 8:23 a.m.
Hey all,
Do O2 sensors have a common thread (diameter and pitch) and if so...what might that be? Most of the one's I've dealt with all seem the same, but in case they're not, this is a mid-80's GM product.
I'm needing to plug where one would go in the y-pipe on my Z28, and figured I'd rather put in a plug than a sensor that will be hooked to nothing. However, the latter may be the best option...
Little help?
Thanks, Clem
Ian F
Ian F Reader
11/13/08 8:28 a.m.
The thread is 18x1.5mm.
Plug:
http://www.diyautotune.com/catalog/innovate-motorsports-oxygen-sensor-bung-and-plug-kit-3736-p-71.html
Although if you call them, they may sell you a plug w/o the bung.
hotrodlarry
hotrodlarry New Reader
11/13/08 9:16 a.m.
I've used oil drain plugs to replace oxygen sensors on some cars.
ClemSparks
11/13/08 9:28 a.m.
hotrodlarry wrote: I've used oil drain plugs to replace oxygen sensors on some cars.
Thank you for that tip...I hadn't thought about that yet.
Between these two replies, I think i'm all set!
Thanks again,
Clem
JmfnB
JmfnB SuperDork
11/13/08 9:37 a.m.
NAPA stocks them as well.
Wally
11/13/08 9:42 a.m.
TP?
ClemSparks
11/13/08 9:55 a.m.
Damnit Beavii!
Don't make me smack you...
njansenv
njansenv New Reader
11/13/08 11:00 a.m.
Many spark plugs share the same thread...... I've used plugs from my neon to plug the secondary O2 sensor hole.
I'm sure those of you with an imagination and an appropriately rich burning vehicle can find more interesting uses for the plug. :)
Woody
Woody GRM+ Memberand Dork
11/13/08 7:21 p.m.
Damn, I need an O2 sensor bung for my Miata's exhaust now that I've removed the race pipe and reinstalled the cat and here you go plugging up a perfectly good one. Any chance you could send it to me if you're not using it?!
By the way, that's an oil pan plug in the race pipe.
Photobucket
mikeatrpi
mikeatrpi New Reader
11/13/08 9:16 p.m.
Buy a spark plug anti-fouler kit from the HELP section of the parts store. Then, cut off the part you don't need and weld on the rest.
(this is for the bung, not the plug by the way!)
44Dwarf
44Dwarf Reader
11/13/08 10:19 p.m.
they sell bungs they even come radiused for the pipe.
ClemSparks
3/23/09 12:20 p.m.
Turns out my y-pipe does not have an m18x1.5 threaded bung in it. I bought an oil drain plug and it's just a bit too small.
So...does anybody have any other advice on what I might have? It's an aftermarket y-pipe and headers (package deal...I got it used, of course) for a third generation F-body (Camaro/Firebird).
My old engine is not on hand (though I can get to it, eventually) to grab the O2 sensor from.
Thanks, Clem
6b5kcBS1Z6LVRP9JPmHxs9A6IZ7agb5FDMpbCgYOfWh8sHM5C4LGg8aWPtGLbq7d
