Toyman01
2/3/16 5:57 p.m.
Which is better.
I have a small gravity pot that works fairly well. But I'm considering sandblasting the exterior of SanFord.
If a pressure pot is substantially better I'd consider buying one. I have enough compressor to push either one without a problem.
Toyman01
2/3/16 6:04 p.m.
Another question. Will soda blasting remove rust?
captdownshift
captdownshift GRM+ Memberand UltraDork
2/3/16 6:40 p.m.
In reply to Toyman01:
Absolutely, it's fantastic at it.
spitfirebill
spitfirebill PowerDork
2/3/16 8:20 p.m.
That's news to me.
And I would say a pressure pot is better than a siphon feed.
Grtechguy
Grtechguy MegaDork
3/21/16 5:31 p.m.
I'm bumping this.. What did you end up using?
Toyman01
3/21/16 5:56 p.m.
In reply to Grtechguy:
I bought a water sandblast kit for my pressure washer from Northern Tool. I haven't had time to try it yet, but I'll post here when I do.
Video of one being used. Not Me.
jimbbski
jimbbski Dork
3/21/16 7:03 p.m.
FYI. Water blasting steel is OK but it will flash rust almost as fast as it dries. You can remove the rust with a phosphoric acid solution that will also leave a coating that you can paint over with etching primer.
etifosi
etifosi Dork
3/21/16 7:48 p.m.
Soda blasting will NOT remove rust.
dqGlKJq6fJEj1yk8m4hjmheT17hlKr4VMHqibuGDs64TJOdal9GYRwFTCinJbDYv
