1 ... 5 6 7 8 9
CyberEric
CyberEric Dork
1/6/21 6:27 p.m.
Ugh. I’m sorry.
I’m astonished by the calamity of errors.
I feel bad for giggling when your Range Rover was the reliable car in the situation.
BoxheadTim (Forum Supporter)
1/6/21 8:06 p.m.
In reply to thatsnowinnebago (Forum Supporter) :
Well, you weren't the only person who got a chuckle out of that .
Picked up a booster box at the local auto parts store in the hope that the leads are long enough. The lithium ones definitely don't have leads that are long enough, but I think (hope) the conventional one does. It's currently on its initial 36h charge, let's hope it has enough juice to at least pop the trunk so I can hook up one of my battery tenders.
jfryjfry (FS)
jfryjfry (FS) Dork
1/6/21 10:29 p.m.
Can't you clamp the neg lead to ground somewhere near the pos post?
1/7/21 11:33 a.m.
In reply to jfryjfry (FS) :
Loads and loads of plastic around the area where the positive post is. I'll remove covers if I have to, but I'd rather not. And given that the car is under warranty and has tons of sensitive Italian electronics, I'd rather not give the manufacturer an opening along the lines of "you didn't follow the manual when jumpstarting the car, and now you fried 4 ECUs".
The covers would already be off if this wasn't a lease/warranty situation .
1/9/21 3:30 p.m.
Hopefully mostly an intermediate update. Got the biggest starter box the local parts slinger had in stock (1200A Schumacher, the full size one, not a Lithium one). Of course that needed charging as well, so there went another 40-odd hours. But it does appear that the starter box indeed clamps onto the jump starting points correctly as doing so was met with a satisfying bunch of clunks as the various electronic and electrical components woke up.
So far, so good.
Unfortunately an attempt at starting was met with the displayed voltage on the jumper pack going down to about 9.1V, the same sad noise from a starter who wants to but just can't mesh, and a warning (and other) light show that was even more spectacular than before. I definitely wasn't aware that this car had quite so many warning lights. Plus, the DRLs flashing all wonky was a nice touch, too.
At least, I was able to pop the trunk with the jumper pack connected - oddly enough, first thing I did before I tried to start the car, I wonder why - and could get at the battery. Hooked up my 3A battery tender only to be met with the "What battery?" light flashing. Yay. Ended up having to dig out the old Schumacher "I don't care what I'm connected to, I'll charge it anyway" charger I have for such cases. Hooking that one up carefully as there are very specific instructions as to what needs to be connected where, and we finally had some charge going in. Enough of a charge that I nearly burnt my hands on the clips when I disconnected them a few hours later.
By now the Battery Tender is reporting at least 80% charged. As I have to hop over to the xfinity store tomorrow, I'll leave it on the charger for another night and see if it starts. Wish me luck, because I don't really have time next week to fit in a call to the breakdown service and deal with the dealer.
1/10/21 4:34 p.m.
Good news, it started (more than once) and I got to drive it around to run some errands.
I had to restart the car a second time to extinguish the remaining christmas tree lights, but it behaved OK otherwise.
Let's see if it behaves now or if this happens again. Fortunately right now I can work around it, but this is not something I want to have to worry about if the car is parked at the airport for a week.
Sonic
Sonic UltraDork
1/10/21 6:46 p.m.
Probably best to leave the well charged battery jump box in the trunk for now.
1/10/21 7:47 p.m.
In reply to Sonic :
I'm not sure the trunk is quite the right spot to keep the battery box - see post on previous page that you can't get into the trunk without sufficient electrical power left in the battery.
But yes, if I'm traveling further than the next town over I probably take the box with me. Just in case. My big concern however is tha thte box on its own didn't manage to start the car, so having the box in the car might just make the power to weight ratio worse. I still think it's a good idea though.
Sonic
Sonic UltraDork
1/10/21 8:25 p.m.
Touché.  Back seat for the jump box!
NOT A TA
NOT A TA SuperDork
1/10/21 8:49 p.m.
Have the battery tested. If it's a traditional lead acid battery then sitting dead for possibly 10-14 days while it ate itself seriously reduced the life of the battery. Notify the service dept at the dealer via email & include a link to this thread to document.
1/11/21 10:41 a.m.
In reply to NOT A TA :
That's a good point. I suspect there is a specific test procedure (or I have to remove the battery for testing) as the owners manual specifically calls out that there is a charge controller that's connected directly to the battery and that one has to use very specific contact points to charge the battery.
Probably should to go to the dealer to get the battery tested so I don't run into arguments about "testing was wot did the battery in" later on.
Either way this whole episode has left a bit of a "I'm too old for all of this modern stuff" taste in my mouth.
06HHR (Forum Supporter)
06HHR (Forum Supporter) Dork
1/11/21 1:18 p.m.
Glad to see you found a workaround to get the trunk open.  I really want one of these (or a Stelvio) and used ones seem to be priced pretty reasonably for a near-luxury sports sedan.  But no Alfa dealers within 150 miles of my location kinda puts a damper on that want, and i'm not sure i'm up to DIY service a modern Alfa.  Anyway beautiful car and i'm rooting for you.
nderwater
nderwater UltimaDork
1/11/21 3:40 p.m.
I got a small chuckle at your misfortune but frankly, everything you describe pales against what I've experienced with my Boxster recently.  Convertibles are bound to leak or (heaven forbid) be caught top-down in the rain, and brilliant Porsche engineering ensured that any significant water intrusion into these cars is catastrophic.
1/21/21 7:50 p.m.
Ah yes, the wonderful Porsche engineering for their convertibles. My 911 Cabriolet also has signs of water ingress, and placing the ECU on the floor is such a brilliant idea on a car like that.
On the positive side (insert battery joke here), the Giulia fired up fine this evening after standing for something ten days. I'm wondering if the issue was that the last time, I left it unlocked.
759NRNG (Forum Partidario)
759NRNG (Forum Partidario) UberDork
1/21/21 8:16 p.m.
The unlocked part having to do with security circuitry......or the door not being fully closed allowing moisture into the interior???
1/21/21 8:26 p.m.
In reply to 759NRNG (Forum Partidario) :
I suspect security circuitry. It was parked in a dry garage.
BoxheadTim
6/18/21 7:04 p.m.
Right, not much to report as I've been driving the car and it's been working well.
Until today, when I needed to drive to Sterling VA to hopefully acquire an SA2020 helmet.
Doors wouldn't unlock and interior light was extremely weak. It's not like I hadn't been driving the car, it stood maybe 3-4 days if that, which has never been an issue.
Fortunately I had a fully charged jump box handy and managed to get it going quickly, but this is getting a little annoying.
Sidewayze
Sidewayze Reader
6/18/21 8:26 p.m.
Just a quick thought.
You didn't leave the key in or near the car, did you?
I've had experience with Dodge trucks that will operate enough electronics to kill the battery in a couple days if they sesnse the key nearby.
BoxheadTim
6/18/21 9:15 p.m.
In reply to Sidewayze :
Depends on what "near" means. They're not in the garage, but generally stored about maybe 20-25' and several walls away.
I also make a point of locking the car after every use, and I know that I can't open the doors or trunk if the key is in its usual location, so I think it is out of range.
What gets me is the intermittent and random nature. But then again, Italian electrics...
When I check the Giulia Forum the last time this happened, this did not appear to be an uncommon occurrence. And it's going to become more of a concern if an when I get back to traveling for work. Nothing berkeleys up one's weekend more than being stuck in a parking garage at BWI or Dulles at 11pm on Friday, waiting for the jumpstart fairy.
BoxheadTim
6/18/21 9:18 p.m.
At least I managed to buy a helmet and get back home without further issues.
Aaron_King
6/21/21 10:13 a.m.
We have been having odd electrical issues with my wife's 10 SAAB 9-5.  I guess these cars have a habit of going through batteries, I suspect due to the fact that the turbo is like 5 inches from the battery.
BoxheadTim
6/21/21 1:27 p.m.
In reply to Aaron_King :
ISTR that SAABs were notorious for that, especially the C900 turbos, because putting the battery right next to the turbo makes sense for longevity.
In case of the Giulia, the battery is more or less at the opposite end of the car to the turbo, yet they still seem to have longevity issues - Pistonheads just had a buyer's guide for the QV, and one issue they list is the short battery life.
Aaron_King
6/21/21 1:53 p.m.
In reply to BoxheadTim :
I know there was no direct correlation, just venting because we are dealing with this again so soon.  Sorry for clogging up your Alfa thread.
I still want a Giulia, but don't know if I could bring myself to buy an Alfa with an auto.  I still miss my GTV-6.
BoxheadTim
6/21/21 2:16 p.m.
Totally agree on the batteries, it's an annoyance if they don't last.
I recently chatted with a colleague of mine and fellow Giulia owner who lives in Europe and had a chance to sample both the manual and the automatic version of it. His verdict was pretty similar to the reviews I read, namely that the manual isn't particularly good compared to the autobox. Which is a bit sad, but the 8 speed auto is rather good for a non-dual clutch transmission, especially with paddles when you really want them.
I find I use the paddles fairly rarely though as both in sport and normal modes, the transmission usually shifts when I want it to anyway. Keep in mind that while the engine is a bit of a technological marvel, it's still your average turbo tractor four banger with a fairly low redline. The Alfa engines of old certainly were a lot more engaging to me.
That opinion might change if I ever get to drive a QV, though.
1 ... 5 6 7 8 9
NIbg2vOAc0i0O6EV1ylNfktrYPIASLnWrWeX4dvPHwZAwNAsaUYkIBdp7Gx77eHi
