JohnInKansas
JohnInKansas HalfDork
7/18/12 4:49 p.m.
Little brother is having issues with our autocross car. 2002 VW GTI 1.8T.
Ambient temp 105 (+/-). Coolant temp 195 (+/-). Pavement temperature easily 130+.
Car starts and runs fine when the ambient is lower (in the mornings and at night), but as temperature rises, it stalls/dies when the throttle is closed. In or out of gear. Sometimes when leaving a stoplight. Starts back up easily enough. Happens more often in lower-speed driving. He said it died about 20 times () on his way home from town today (about an 80-minute drive, half of which is city driving).
I suspect vapor lock, but I don't know much about modern fuel systems.
Any thoughts on this would be greatly appreciated.
emodspitfire
emodspitfire Reader
7/18/12 5:04 p.m.
CEL on? Any codes?
JohnInKansas
7/18/12 5:11 p.m.
He said "its a VW, of course the CEL is on".
Random Misfire, Random Misfire in 1/2/3/4, Lean Condition Bank 1, Idle Airflow Too High. He's had those for months though, and this issue has just started in the last ten days.
vwcorvette
vwcorvette GRM+ Memberand HalfDork
7/18/12 5:27 p.m.
Sounds like vacuum leak? Really, though, running with mis fire codes a sure way to kill the catalytic converter. Possible MAF problem as well. If you don't already have one get a Bentley manual and follow the diagnosis for the codes.
tpwalsh
tpwalsh Reader
7/18/12 5:52 p.m.
Those cars are really bad on coil packs. I've been through at least a dozen in 7 years and 195k. I'm with vwcorvette as well, sounds like he's got a vacum leak as well.
JohnInKansas
7/18/12 7:26 p.m.
He replaced the coil packs about 10k ago. Might be time for another set.
Vaccum leak as in a loose line somewhere?
He is (and I am) puzzling why it doesn't seem to have trouble when the ambient temperature is lower.
iceracer
iceracer UltraDork
7/19/12 9:04 a.m.
Driving the car with all of those problems, I'm not surprised.
DukeOfUndersteer
DukeOfUndersteer PowerDork
7/19/12 9:09 a.m.
VWCorvette is correct. Sounds like a vacuum leak. Cars of that age are having more of these problems when the hoses start to crack and deteriorate. I would start checking all the rubber hoses for cracks and holes.
QWhIVO5EeIUfOTBKqMiRlGi0WzkmDirFaBO4CywbBzbaLBIu5UkQhbSpv8n1ZzNj
