Any advice on freshening up rusty old caliper brackets? I need to replace my rear calipers and don't want to mount up the clean new units to nasty looking brackets.
Thanks for your insight!
-Ray
How much rust? Surface rust or super, pitted rusty? Steel wool or wire brush. Then you can paint them any color you like with caliper paint.
I wirebrushed, sandblasted, and soaked mine in Ospho for a day. Then I painted them with BBQ grill paint and baked them (in a bbq grill) to set the paint.
You could also try leaving them in vinegar for a week or two. Or maybe if you have less time, electrolytic rust removal works well but can be a pain to set up.
sandblasting is the best if you have access to such equipment. Otherwise, whack the piece with a hammer. Preferably a pointy one. The layers of rust will crack off and it won't look so crusty anymore.
I've had pretty good success using a wire wheel attached to a drill. It makes quick work of the rust. Afterwards, I wipe it down with a bit of solvent or brake cleaner then a few coats of grill paint.
I brass brush and some WD40 tends to work wonders on a lot of rusty surfaces.
I freshened up an early 70's road bike (bicycle) that way.
Electrolytic rust removal works pretty good if you've got time and no sandblaster... All you need is a bucket, water, 'washing soda', and a battery charger.
http://www.instructables.com/id/Electrolytic-Rust-Removal-aka-Magic/
I'll also vouch for the electrolytic derusting process. It hasn't failed me yet. Kills rust, but leaves behind clean metal.
