RoadWarrior
RoadWarrior Reader
7/29/10 8:31 p.m.
Hey guys, So...my 94 miata just gained a pretty weird issue as I was driving it tonight. I haven't driven the car in about 2 weeks and decided to go for a spirited drive. I'd get a loss in power (almost like a fuel cut) usually around 3-4k rpm, but that would vary , sometimes much much lower lower. The CEL did blip on once and disappeared. I decided to pull codes and it seems that i'm getting a 4 (no SGC signal) and a 17 (which IIRC is an o2 sensor related code). Any decent way to test the CAS to see if that's really the issue? The only info I foudn seems that putting it on a scope is the only true way to test it. Would the o2 sensor failure really cause a fuel cut like that? I restarted the thing and it seems to be ok since pulling the codes. I'm stumped.
Keith
7/29/10 9:56 p.m.
Is the tach flatlining when you get the blip? Check the wires going into the CAS, they have a tendency to crack. Get the car idling and do a good wiggle test.
RoadWarrior
RoadWarrior Reader
8/2/10 1:23 p.m.
Well, fixed it in about 5 mins. As soon as I got to my gf's house I broke out the flashlight and poked around. I noticed the o2 sensor was routed kinda off (as in basically laying on the exhaust manifold. I disconnected/reconnected both that and the CAS and fixed the routing of the o2..and it's been fine ever since!? Weird.
YarYnh9k5nKPBj8H5IIpx1uuksl7Mz6eTzMdZ66ej4yg3LV2qmBa3t3eZ2PJEgB1
