ArthurDent
ArthurDent HalfDork
5/30/12 11:48 a.m.
The seller I bought the Honda from took a quick look and thought it was a Ford 9". The more oval sort of shape indicates a 8" doesn't it? Worth anything?
Thanks!
rear diff
rear diff
Curmudgeon
Curmudgeon MegaDork
5/30/12 12:04 p.m.
I swear that looks like a 9 incher to me, and yes they were oval housing. The only thing that throws me is the pinion bearing housing does not unbolt. Both the 8 and 9 inch had a removeable pinion bearing housing.
stuart in mn
stuart in mn UberDork
5/30/12 12:26 p.m.
I'm guessing it's a 1955-1964 Chevrolet rear axle. There's a picture of one in this thread: http://forums.corvetteforum.com/c1-and-c2-corvettes/1470163-advice-on-the-rear-axle.html They used to be easy to find and cheap, but they're not particularly strong. Check to see if you can find 'GM' cast into the center section.
bravenrace
bravenrace PowerDork
5/30/12 12:34 p.m.
Unless it's some obscure vintage, it's not a Ford rear. None I've ever seen have that pumpkin design. I'm also guessing an old GM rear of some sort.
ArthurDent
ArthurDent HalfDork
5/30/12 1:00 p.m.
Hmmm ... that does look like this Corvette diagram
Curmudgeon
Curmudgeon MegaDork
5/30/12 1:04 p.m.
Going by this pic, yeah it probably is a olde olde GM rear axle.
foxtrapper
foxtrapper UberDork
5/30/12 1:12 p.m.
Looks like a Ford 9" to me.
Edit. But I think I'm wrong. Further investigation leads me to suspect it's something called a GM 8.2 dropout differential.
http://www.jdrace.com/Rear_ID/10b82chevyD.htm
http://www.chevytalk.org/fusionbb/showtopic.php?tid/244993/
ArthurDent
ArthurDent HalfDork
5/30/12 1:24 p.m.
I think it might be a '57 Chevrolet something or other.
This looks pretty similar http://www.jalopyjournal.com/forum/showthread.php?t=201274
ReverendDexter
ReverendDexter UltraDork
5/30/12 4:44 p.m.
It's definitely not a 9" There's no plug on the back of the Ford, and while they're slightly oval, they're much more round that the diff in that pic.
iceracer
iceracer UltraDork
5/30/12 4:56 p.m.
Timken made a similar axle. It was used on the really old Jeep pickups. Ford also had a similar design. Without identifyimg tags or marks it is really hard to tell.
4jEKiuu9Gs6m88E39EzIeKUrfUdoqJelKBbZImdDraRaqxo65ILCt6iH7sfo5DEA
