JG Pasterjak
5/20/22 12:26 p.m.
What makes the ideal track car?
Good question. One look at any grid shows that the answers are as varied as the people doing the driving.
The ideal track car could be a turnkey offering, a homebuilt special or just an unassuming sedan. It could be box-stock or incredibly complicated.
But what kind of car shopping advice can some experts …
Beer Baron
Beer Baron MegaDork
5/20/22 1:04 p.m.
One that you won't lose any sleep if you wad it up and are able to walk away.
spacecadet (Forum Supporter)
spacecadet (Forum Supporter) GRM+ Memberand UltraDork
5/20/22 1:22 p.m.
One you can walk away from and not be financially devastated from is rule #1 and definitely the most important.
if i wadded up my fit I'd definitely lose some sleep being sad i'd done it.. but i'd tear off the still good parts and put together a new car over time and be right back at it.
ClearWaterMS
ClearWaterMS Reader
5/20/22 1:34 p.m.
The one currently in your garage...
bobzilla
bobzilla MegaDork
5/20/22 1:36 p.m.
this. Already have my eye on a white LX from Texas.
Olemiss540
Olemiss540 HalfDork
5/20/22 2:33 p.m.
The one that runs consistently. Still looking for that one.
akylekoz
akylekoz UltraDork
5/20/22 2:46 p.m.
A few answers from the OP resonate with my choice.
It's what I have.
Easy to modify.
Plenty of aftermarket support.
9/10ths isn't insanely fast.
Fun to drive/like the looks of.
Fits my life of hauling kids, and an occasional road trip.
However I would be upset if I balled it up.  See fun at 9/10ths and at sane speeds.
Cannot stress enough, to just get out there.  Building is fun but knowing what needs the most help first while enjoying what you have is the way to go.
If I could start all over I would just sign up and go.  However that is easier now than thirty years ago.  TNiA and any other HPDE with a well run novice class is the best opportunity out there to get involved.
edmagoo
edmagoo New Reader
5/20/22 2:48 p.m.
I had a bunch of style, cost, and utility criteria that I was able to meet when I chose my race car but there was one thing I didn't think about. The size of the class that I would race in. I was often in the slow class of the fast group or the fast class of the slow group and not many in my class.
You can always race against yourself and just try to do your best under the circumstances but it is nice to actually compete against another person. Even someone about your speed in another class is good but I often found myself alone on the track. (or maybe I should have just raced with bigger clubs)
frenchyd
frenchyd MegaDork
5/20/22 3:18 p.m.
In reply to edmagoo :
Race what you know.   If you are overwhelmed mechanically you will always be tentative, afraid you're going to hurt it. Thus hesitate to take openings or push it past redline.
  If you need a mechanic with you, it doesn't matter if it's a common car or not.
    Knowledge is power.  Real power on the race track.  "Aw heck,  if it goes bang I'll just grab another engine and go back racing".   Or That's the cars absolute limit, don't go past that.
   I learned that from a Formula  V driver.
he could swap motors with anyone and still win.  In fact with some of the cheating motors he could run too fast.
Same with the really good formula Ford drivers.  They'd have engine swaps down to a 1/2 hour or less.  Take someone's old tired engine and go beat the field.
    When I raced the DeMar I almost always won but when the owner drove it  he felt good if he wasn't lapped.
              Knowing how hard you can push something is worth a lot of extra horsepower or handling.
        Look inside of yourself.  How close to the edge are you comfortable?   Will you slide the tires slightly past control knowing the crest will give you back the control you lost?  Can you tuck up to someone's back end to get a full draft  and then dive out at the last moment in an outbraking maneuver or do you need someone to wave you past?  When he's waving you past do you know if you should take the wave bye or wait for a cleaner opening?
    I remember one race where I went into a corner waving the Porsche by on the outside.  I didn't let off, I still was flat out but he pushed it past redline by a bunch and yep it went bang in a really expensive way. For a moment there he was past me.  But only for a moment.
 He violated the first rule of racing.  Which is drive your car.  It was his obligation to know his cars limits.
dannyzabolotny
dannyzabolotny Reader
5/20/22 6:36 p.m.
Sometimes you just go with what you want to track, regardless of practicality, parts availability, etc.
That's what I did with my 1992 525i/5. Since it's got an M50 and a ZF transmission, it shares a lot with the E36, so I was able to use an E36 M3 clutch/flywheel setup. As for the suspension, BC makes coilovers for the E34 so that was that. I also found some really rare Racing Dynamics sway bars to help handle the weight. Control arm bearings were made by an E34 enthusiast, and customer camber plates were made by another enthusiast. There's one decent seat adapter made by VAC Motorsport, so I went with that. And topped it off with some E36-spec Apex ARC-8 wheels.
Thankfully the E34 has just enough of a community to make tracking it feasible, and enough crossover with E30 and E36 parts that I can "borrow' things from those cars, like an S50/S52 if I wanted more power.
Despite being slower and heavier than a lot of other track cars, the E34 did incredibly well and served as a great platform for me to learn on. And I had a second E34 as a backup, so when I totaled the white car, I just transferred everything over to my second E34, which will be hitting the track next month.
J.A. Ackley
J.A. Ackley Senior Editor
4/24/24 4:45 p.m.
I'd probably recommend the path of least resistance. The easiest way that you can hit the track that still brings a smile to your face and keeps you safe is probably the best way.
Unless you like pain. Then proceed accordingly. laugh
ClearWaterMS
ClearWaterMS Reader
4/24/24 5:37 p.m.
did you resurrect this old thread just so you could slide in that masochist joke?
buzzboy
buzzboy UltraDork
4/24/24 10:19 p.m.
I tried endurance racing a Subaru last weekend. I realize I don't like pain!
DaleCarter
DaleCarter GRM+ Memberand Reader
4/25/24 8:24 a.m.
Looking through my shop at the cars I own or share with others, the only two that are always ready to go are the NB Miata (E-street setup) and the Spec E36. I drive a K-swapped Miata in Champ and Lucky Dog that is a hoot. They, are the cheapest to acquire and maintain, plus develop me as a driver better than the others.
The Miatas have the additional benefit of being the most fun and giggle causing of all the cars avaialble to me.
theruleslawyer
theruleslawyer Reader
4/25/24 12:57 p.m.
So Im hearing, run a Honda accord?
J.A. Ackley
4/25/24 4:55 p.m.
Not my original intent, but, hey, if there's an opportunity.
Tom1200
Tom1200 PowerDork
4/25/24 9:47 p.m.
Can't believe I missed this first time around.
My right car has to be fun, reliable and cheap to run.........I don't care about fast. Fast is nice but the other things are more important to me.
livinon2wheels
livinon2wheels GRM+ Memberand Reader
9/4/24 2:28 p.m.
In reply to J.A. Ackley :
I think maybe you have tried the painful way... I happen to agree with you. Path of least resistance and try to plan for when Murphy's Law kicks in. Two diametrically opposed mindsets but planning for contingencies is part of the learning curve, at least in my experience. Too many times I failed at this and it bit me in the butt at an event I wanted to run but car trouble, actually failure to plan properly took me out of contention before I ever got to really put it out there. Lots of hard lessons to be learned if planning for contingencies is not your forte.
livinon2wheels
9/4/24 2:29 p.m.
In reply to dannyzabolotny :
Beautiful car...really nice. That has got to be so much fun to drive...
racerfink
racerfink UberDork
9/4/24 2:56 p.m.
I've had the opportunity to run with a couple of teams for several races in both Champcar and WRL.  The ones that consistently do well year after year are the teams that are prepared , and also keep the car simple.  When the car starts getting complicated, so do the ways it can break down and ruin your race/track day.
kb58
kb58 UltraDork
9/4/24 3:12 p.m.
No need to read the article, as there is no One answer.  What's next, "What's the best color for a car?!"
ClearWaterMS
ClearWaterMS HalfDork
9/4/24 3:28 p.m.
as long as it has color (white, black, and shades of grey are shades not color)
wearymicrobe
wearymicrobe PowerDork
9/4/24 5:22 p.m.
The best track car is.
Someone else's fully shaken down and used track car in budget. Especially if it comes from a spec series still being run.
Allan
Allan New Reader
1/26/25 4:24 p.m.
This was a nice chatty bit, but it isn't really helpful for somebody getting into the sport (aside from the 'make sure you can afford it' - but they don't really talk about details).    I was really hoping for some concrete suggestions - not that I have any intent to change what I'm tracking, but for new people who are just starting out and just got the bug.
Would be nice to get a followup with more of the specific models people love that are more affordable.  Especially with a focus on cars that an early driver can track without major mods (i.e. don't need BBK's, cooling/intercooler upgrades, chassis/suspension fixes to handle track duty).   Miata, BRZ, E36/46 come to mind as the common ones, but are there others being missed?  Any with hidden money pits like engines that grenade on track (Ford 4's), unworkable suspensions, brakes that won't cut it even with good pads/fluid, cooling systems that won't last a full session, etc.  I've heard a few of these, both positive and negative, but would love to hear more informed opinions.
johndej
johndej UltraDork
1/26/25 6:11 p.m.
I've seen way more accord/civic/corolla/etc. at track days than many popular sports cars you would expect to see track time. With a good driver they'll run those guys down and pass them too.
ouzM1fVJviDKKTP8BgLA09o5512YxmLnpXRJhoVvvvZQaT0YkadR4JMrINALSO28
