Robbie
Robbie GRM+ Memberand PowerDork
4/16/18 9:49 a.m.
Or, more correctly, what can I use as tire bead lube if I don't want to buy and store a big tub of the stuff that I will use approximately once per almost never.
I guess I'm ok buying something, but if it ages out i'd rather just use something I may already have on the shelf.
Soapy water? PB Blaster? CRC something (hint hint GRM)? Mix of bleach and orange juice?
RevRico
RevRico GRM+ Memberand UltraDork
4/16/18 9:50 a.m.
Warm Soapy water always worked for me.
frenchyd
frenchyd SuperDork
4/16/18 9:52 a.m.
In reply to RevRico :
I’ve used  mechanics hand soap too
HFmaxi
HFmaxi New Reader
4/16/18 9:58 a.m.
Klein conduit lube works pretty well on suspension bushings would probably do well on tires too.
John Welsh
John Welsh Mod Squad
4/16/18 9:59 a.m.
Is there anything in the night stand that might work?
Ian F
Ian F MegaDork
4/16/18 10:00 a.m.
Strong mix of dish soap and water in a $3 spray bottle.
KyAllroad (Jeremy)
KyAllroad (Jeremy) PowerDork
4/16/18 10:00 a.m.
Was trying to come up with a polite way to say that. devil
Robbie
4/16/18 10:02 a.m.
amazon dot com thinks so:
NEALSMO
NEALSMO UberDork
4/16/18 10:05 a.m.
Soapy water or degreaser
John Welsh
4/16/18 10:05 a.m.
In reply to Robbie :
That Amazon result is likely due to some things in your recent browser history. devil
4/16/18 10:10 a.m.
This is what the cheap tire shop where I get most of my tire installation done uses.
Robbie
4/16/18 10:21 a.m.
I was looking for massage oil! I swear!
tags: college, part-time jobs, soapy water, uniform, two-men-one-tire, lube, greasy, workplace, bosses, punch in/ punch out
Gosh I crack myself up.
Patrick
4/16/18 10:48 a.m.
Keep a tube of K-Y in the garage for annoying hose assemblies that just don’t want to go together
jharry3
jharry3 GRM+ Memberand Reader
4/16/18 10:53 a.m.
We used to just mix water and dish detergent at the tire place I worked.
Just brushed it on, sometimes you could get the beads over without a tool with just soapy water.
Probably not with the super stiff sidewalls of today's low profile tires.
Dead_Sled
Dead_Sled New Reader
4/16/18 10:54 a.m.
I've had good luck using CRC heavy duty silicone spray when mounting tires by hand.  Spray down the bead and the rim and they slide right on.  Shouldn't have to worry about shelf life.
pinchvalve
4/16/18 10:57 a.m.
With this, you'll be able to get it on.
Brown chicken brown cow.
codrus
4/16/18 11:57 a.m.
If they're fancy French tires (Michelins) then I think you need to use duck fat.
Cousin_Eddie
Cousin_Eddie Reader
4/16/18 12:06 p.m.
Goop Hand soap is the cat's pajamas for installing tires as well as any type of window glass that uses a rubber molding.
For stubborn hose assemblies (as mentioned above somewhere), Honda Shin Etsu grease. That's what it's made for, and those little Honda engineers know their stuff.
Kramer
Kramer Dork
4/16/18 12:10 p.m.
Gilbert Gnarley loves Kentucky Jelly.
Not too many people will get that.  Those who do will laugh their butts off!
dculberson
dculberson UltimaDork
4/16/18 12:33 p.m.
I use Dawn dish soap on stuff like this. The advantage to it over greasy things is that it mostly evaporates and leaves little behind to make a de-beading problem later. Oily stuff will stay oily for a very long time.
I have a small bottle of Dawn in the shop that will last me a few years and cost $1.
NyTWct1URhKxHOCwU7iVPiQJFYdg0T0TYYleuMA1KjFpIHQgD61BgIdk7WzVzV6F
