smog7
smog7 Dork
10/1/08 2:08 a.m.
My st185 celica all trac is in desperate need of new brake rotors... the only thing is that oem, and brembo oem blanks cost an arm and a leg. Out of which parts stores, nappa, kraggen, carquest, etc offer the best bang for the buck rotors?? also, I just recently (less than 5k miles) replaced my pads. since I dont have the money for new pads, should I scuff up the surface of the pads when installing the new rotors? or is their just no way of using old pads with new rotors?
foxtrapper
foxtrapper SuperDork
10/1/08 6:10 a.m.
Parts America (Advance, etc) lists them for $21-$52 front, $18-$42 rear.
Raze
Raze New Reader
10/1/08 6:54 a.m.
rockauto...
GameboyRMH GRM+ Memberand Dork
10/1/08 11:01 a.m.
It's actually better to use old pads with new rotors to help "break in" the new rotor surface...but yeah scuff them up first.
maroon92
maroon92 SuperDork
10/1/08 11:50 a.m.
I got a great deal on my brembo OEM replacements from Tirerack.com
93celicaGT2
93celicaGT2 Reader
10/1/08 12:02 p.m.
smog7 wrote: My st185 celica all trac is in desperate need of new brake rotors... the only thing is that oem, and brembo oem blanks cost an arm and a leg. Out of which parts stores, nappa, kraggen, carquest, etc offer the best bang for the buck rotors?? also, I just recently (less than 5k miles) replaced my pads. since I dont have the money for new pads, should I scuff up the surface of the pads when installing the new rotors? or is their just no way of using old pads with new rotors?
On that car, you'll be wanting to actually pony up the cash to not get Chinese-cheaply-made replacements from Autozone or the like.
Either get Toyota replacements, or Brembo blanks, or enjoy major warping from your 3400lb celica trying to stop time and time again.
If i can warp Autozone/o'reilly rotors time and time again on my 92 GT stripped down and weighing almost 1000lbs less than your car, think what you would do. With a JDByrider discount, i spend just under $200 at O'reillys to get new rotors. It's MORE than worth the extra money to get some quality rotors.
I would spend the $300 give or take just for the peace of mind.
Parts are expensive for AllTracs/Celicas in general, once you accept that, you'll be a lot happier. :)
Check out 1sttoyotaparts.com, they usually undercut dealer prices by a wide margin, and will probably be your best bet.
pinchvalve
pinchvalve GRM+ Memberand SuperDork
10/1/08 12:33 p.m.
1st Toyota has great prices and service. I have also had great success with Rock Auto, and they give you lots of options including great prices on name-brand rotors.
93celicaGT2
93celicaGT2 Reader
10/1/08 12:42 p.m.
Smog7,
Are you on Alltrac.net or celicatech.com?
May be worth getting another opinion from them. I'm on both, and they tend to echo the same two places if i remember correctly. I just personally buy Brembos now, although at the moment i'm waiting on development of a cheap BBK based on an STI setup.
smog7
smog7 Dork
10/1/08 1:24 p.m.
yup i'm on alltrac.net, I just wanted to get the grassroots opinion I've ordered through 1sttoyotaparts.com before, they are awesome! so it looks like I will be ordering my rotors from them..
93celicaGT2
93celicaGT2 Reader
10/1/08 3:09 p.m.
smog7 wrote: yup i'm on alltrac.net, I just wanted to get the grassroots opinion I've ordered through 1sttoyotaparts.com before, they are awesome! so it looks like I will be ordering my rotors from them..
Sounds like a plan. I just ordered a CS bumper through them, great site. Undercut my local dealership by about $80, even when including shipping. :)
Now, if i could just manage to find the part numbers for the factory fogs that go with that bumper, i'd be golden. :(
smog7
smog7 Dork
10/1/08 4:01 p.m.
you could always use the fogs from a 5th Gen Celica ST/GT http://www.alltrac.net/phpBB2/viewtopic.php?t=14958&highlight=
*so I should be ok using my old pads with new rotors right??
SupraWes
SupraWes HalfDork
10/1/08 4:14 p.m.
smog7 wrote: you could always use the fogs from a 5th Gen Celica ST/GT http://www.alltrac.net/phpBB2/viewtopic.php?t=14958&highlight= *so I should be ok using my old pads with new rotors right??
I'd call that an old wives tale. Do any new cars come equipped with used pads, even including race cars? Didn't think so.
smog7
smog7 Dork
10/1/08 11:31 p.m.
smog7 wrote: *so I should be ok using my old pads with new rotors right??
93celicaGT2
93celicaGT2 Reader
10/2/08 8:17 a.m.
Yeah, i was going to try that. I have a 92 GT w/ fogs. I would just rather have the sweet cs squares.
There's two schools of though on the pads.... Personally, if the pads have plenty of life left and no uneven wear, i'd go ahead, as long as you can verify that they won't cut grooves in your rotors. If you're just driving the car non-competitively, then fine.
If you've had the pads for any real amount of time? I'd just suck it up and get new pads at the same time. If you want good on the cheap, then grab some EBCs. I've run green, red, and yellow on my car, and loved them all. Red would be a good match for a non-competitive but still tossed-around alltrac, and they won't break the bank. I got my last set for all four corners for $140.
Dr. Hess
Dr. Hess SuperDork
10/2/08 9:52 a.m.
What is a CS bumper, what did it fit (year, model, "born on date"?) A lamp unit, fog lamp, RH for a 8910-9309 ST185 is a 81211-20150, for example.
93celicaGT2
93celicaGT2 Reader
10/2/08 10:38 a.m.
Smog... i think we're going to jack your thread. I hope you were happy with your answers.
Dr. Hess, this is a CS bumper, and i need the fog lights shown.
The part number for this bumper cover is: 52119-20929
I think the part number that you put up is for the "regular" ST185. This bumper came on the ST185RC, CS Edition, and the GRP A. special editions.
amg_rx7
amg_rx7 New Reader
10/2/08 11:18 a.m.
I recently started using Centric rotors that I bought from zeckhausenracing. They wound up being cheaper than Brembo blanks (in my Mini) and they look so much nicer. The surface looks properly machines with nice cross hatching vs dull on the Brembos out of the box.
Good stuff.
I use RacingBrake rotors on the RX7 which gets tracked but that is a different story.
Dr. Hess
Dr. Hess SuperDork
10/2/08 1:26 p.m.
I don't show anything for that 52119-20929 in my EPC. It must be on a disk I don't have loaded. For JDM, I only have the disk with the 20v loaded, which also includes the ST20# celi and some other weird stuff we've never heard of like the Ipsum and Harrier. My USDM EPC has ST185, but not your part number. I get 52119-20917 for a cover, front bumper, ST185 Wide body.
93celicaGT2
93celicaGT2 Reader
10/2/08 1:40 p.m.
Dr. Hess wrote: I don't show anything for that 52119-20929 in my EPC. It must be on a disk I don't have loaded. For JDM, I only have the disk with the 20v loaded, which also includes the ST20# celi and some other weird stuff we've never heard of like the Ipsum and Harrier. My USDM EPC has ST185, but not your part number. I get 52119-20917 for a cover, front bumper, ST185 Wide body.
Yeah, it's not a USDM part. I ran it through the dealer locally here, and they can get me the bumper cover, but can't seem to pull the numbers for the fog lights. I think if i could find a vin for a Grp A, i'd be able to do it, but that's not real easy to do in itself.
chknhwk
chknhwk New Reader
10/13/08 6:11 a.m.
I'd never heard of the Centrics until my martial arts/drinking/tracking buddy bought a set for his 350Z. He says they're great quality and they're holding up on the track (aggressive street pads, Porterfield R4-S, IIRC). That Celica looks awesome!
Q86NwItnC0YRbzGyLapkbywsy02JA66V7LPsXBSyXrlRgERmm4jbKsnCar9jfJyk
