Every time I grab my grease gun, I have to spend a half hour figuring out why it will not work. I'll get a couple fittings greased and then nothing. Plenty of grease but for some reason it looses its prime.
Does a trouble free grease gun exist?
Help this grease monkey get grease.
Air bubbles. You are trying to compress air instead of grease. Modern grease tubes are notorious for air bubbles.
I drill a very small hole in the head where it threads into the body about halfway down the threaded area. Back off the tube just till it kisses the hole and a little blob of grease comes out, then quickly tighten it back up.
Having run thousands of cartridges through hundreds of guns, here is what I do: pull the plunger, drop the cartridge in, and thread the head on just enough to keep it attached. Then release the plunger, and then tighten the head up. Unless its a garbage Chinese gun that will always do the job. No priming necessary because all the air is forced out through the loose threads.
Though I don't use it enough to justify the cost, this is the closest I've found to a no mess grease gun.
In reply to rustybugkiller :
I usually buy or have used Lincolns. They are the ones in the tool box of pretty much every machine I am asked to run. I ran excavators for a year and a half during covid and they bought me one from Walmart which I threw away, and then they gave the whole fleet Milwaukee electrics which were awesome. But too pricey for just having around the shop for the occasional lawnmower service.
