Alan Cesar
Alan Cesar Dork
2/23/12 1:18 p.m.
We were scared of the mysteries inside the old ATE master cylinder and its Reagan-era ABS voodoo. We bypassed it, we thought, with some wiring trickery, but we couldn't be sure if brake pressure was properly proportioned or if the system would even work if it lost electrical power. It had to go.
Some Internet sleuthing told us the Ford …
Jerry From LA
Jerry From LA Dork
2/23/12 5:19 p.m.
Why not just "bench bleed" the master cylinder on the car? Bolt it up, run your return lines, use the mechanical advantage of the car's God-given brake pedal. Throw a few rags underneath when you reconnect the brake lines. Easy-peasy.
fifty
fifty HalfDork
2/25/12 11:32 a.m.
What combination of adapters did you use to match the threads of the prop. valve to the threads on the brake line? Would you recommend steel adapters for brake line, or are aluminum, brass etc fine?
Alan Cesar
Alan Cesar Dork
2/27/12 9:48 a.m.
The prop valve came with brass fittings to install to the valve body. Those are required, because the fitting is NPT, not standard brake line thread. To those brass fittings, we attached the brake line with steel fittings.
aFpmoYxdZ1WzgEsi3VRfEWGgVQnCs0RFmuYRVtkquOSc17LFmf9kwbNLcfHirVk1
