Stampie (FS)
Stampie (FS) GRM+ Memberand UltimaDork
7/17/20 6:16 p.m.
I need to turn a device on like 10 seconds then off for like 30 minutes.  It can control either 5 VDC or 110 VAC.  Cheap and something I can do without having to order are bonuses.  I'm stumped.
Mr_Asa
Mr_Asa Dork
7/17/20 6:20 p.m.
It needs to repeat that cycle? For how long?
Stampie (FS)
7/17/20 6:28 p.m.
In reply to Mr_Asa :
Yes and forever.
RevRico
RevRico GRM+ Memberand PowerDork
7/17/20 6:36 p.m.
I can almost guarantee it would be cheaper to order online than at a store, but you're in Florida, surely there's a hydroponics store nearby. A digital Flood and drain timer would be your bet.
Stampie (FS)
7/17/20 11:54 p.m.
Think I'm going to order this tomorrow unless someone can come up with a better solution.
Amazon Timer Thingy
Mndsm
Mndsm MegaDork
7/18/20 8:20 a.m.
In reply to Stampie (FS) :
That looks like the best version I can come up with.
stuart in mn
stuart in mn MegaDork
7/18/20 8:52 a.m.
I have a couple old mechanical light timers similar to this: https://www.homedepot.com/p/Intermatic-15-Amp-24-Hour-Indoor-Plug-In-Timer-White-TN111K/205478759?MERCH=REC-_-pipsem-_-205478760-_-205478759-_-N  I picked mine up used at yard sales for a few dollars each, but even new they're less than $20 at Home Depot.  Intermatic is a good brand name, but there are many others.  It just plugs into the wall socket, and then you plug your device into it.
Edit:  I just re-read your post and you only want to turn it on for ten seconds (I was thinking ten minutes.)  So, this style probably won't work.
noodle
noodle GRM+ Memberand Reader
7/18/20 10:17 a.m.
Check out the local grocery store's produce department and ask what they use to spray down the greens.
Stampie (FS)
7/18/20 10:40 a.m.
In reply to noodle :
Thanks but I'm betting they use an industrial timer that I can't get today.  I just ordered the Amazon timer.  Should be here Wednesday.
Kn9APGjCt0tuxjuWFvRUfxY16ZXg3BfMk2zpJSZPqcJKYaMaJ7ar787zFrAcQ5G3
