secretariata
secretariata GRM+ Memberand HalfDork
5/10/15 1:23 a.m.
Been searching the "Googles" for a kit or instructions to build a reasonably priced CNC milling machine that can cut plastic, aluminum, & steel. Haven't had much success, most of the info I found is for routers to do wood and won't do steel. Optimally, I'd like something with a 2 ft x 2 ft horizontal (x & y) range and 1 ft vertical (z axis). I realize a 2'x2'x1' piece of steel would weigh 960 lbs, so I won't be loading that much steel, but those dimensions should cover anything I'd like to machine. Speed isn't a huge concern, but accuracy/tolerances are. Anybody got leads for something that can be built for under $2.5k?
Edit to correct my typing. 1960 lbs, not 960.
Dr. Hess
Dr. Hess MegaDork
5/10/15 8:25 a.m.
My friend is into that stuff. He says that any milling machine can be converted to CNC with some inexpensive servos and a controller. He has said a few hundred for the electronics. So, given that you want something MUCH bigger than the $400 HF mill, I suggest buying a mill big enough to do what you want and then adding the CNC stuff to it. You should be able to do it for 2.5K. $1K mill, $1K shipping, $0.5K controls.
WonkoTheSane
WonkoTheSane GRM+ Memberand Reader
5/10/15 12:57 p.m.
For 2.5k, you want a Bridgeport that some other sucker has already converted to cnc for you off of craigslist.
jamscal
jamscal Dork
5/10/15 7:58 p.m.
Unfortunately the answer is going to be 'no' in this case.
rHWUAyNgKIAt0YyFPcfJ0FzWqHXe0Fq2iwHyRXliOCR4Dn1rpqldzIjWi7JeKaDq
