CarKid1989
CarKid1989 Dork
10/22/10 2:42 p.m.
Update:
Went to Granger and bought a new pulley for the tractor. Original rear pulley was 9 inches dia. the new pulley is 3 inches.
Gonna pop some beer in the fridge and start channeling/ body droppin the thing.
patgizz
patgizz GRM+ Memberand SuperDork
10/22/10 6:27 p.m.
used up whipped cream cans are an excellent source for a quick burst of nitrous on small engines.
get some reddi whip and some pumpkin pies. when you eat the pies up shoot the rest of the reddi whip into your mouth and make funny faces at your brother. then run a hose from can to air filter and off you go. mad power.
CarKid1989
CarKid1989 Dork
10/22/10 10:59 p.m.
After much blood sweat and beer the tractor now is 300% better then stock (according to my poor math calculations)
I threw it all together to take a ride stock to make sure it all worked before i took it apart and messed with it. it all worked but holy crap that thing is slow.
so i got to work
After swapping the factory 9 inch transaxle pulley with a 3 inch pulley from Granger and getting a new belt i went for a ride around the block.
This thing surprised the hell outta me. I started in gear 2 and got it rolling and got bored so i put it into 6th gear and went all out on the throttle and let the clutch out. It lurched, and took off fast enough to where my heart jumped a beat and my body tensed to keep me on the damn thing. hahaha it was a riot!
So i had a van pace me and with the pulley swap and the deck off and me pushin on the governer a bit i mustered 17 MPH.
17 MPH!!
Freakin insane. felt great but steering was a bit vague.
Ill be going back to Granger to find a larger pulley for the engine. Hopefully tomorrow.
CarKid1989
CarKid1989 Dork
10/22/10 11:03 p.m.
can i sandwhich a crank pulley between two of these and have to hold strongly/ safely enough to drive?
thatsnowinnebago
thatsnowinnebago GRM+ Memberand Dork
10/23/10 12:35 a.m.
Its got a governer? And its still installed?
Derick Freese
Derick Freese HalfDork
10/23/10 12:50 a.m.
I do have access to a pair of mowers that have useless decks (but rust weighs nothing!) that I have access to. You guys are horrible enablers!
Mikey52_1
Mikey52_1 HalfDork
10/23/10 12:54 a.m.
YEESSS, aren't we?
Mikey52_1
Mikey52_1 HalfDork
10/23/10 12:56 a.m.
Seriously though...you may want a LEETLE more wheelbase before you get too crazy. Really.
Then you could put your brother's mower's engine. A sort of grassroots Frieght Train, as it were...
pete240z
pete240z SuperDork
10/23/10 8:41 a.m.
Riding lawnmowers never go for $50 around here, you got a great deal.
I have been looking at old Cub Cadets and they easily get $300-$600 for beaters.
CarKid1989
CarKid1989 Dork
10/23/10 9:32 a.m.
Derick Freese wrote: I do have access to a pair of mowers that have useless decks (but rust weighs nothing!) that I have access to. You guys are horrible enablers!
Start tinkering with em.
Honestly i was in a little project car slump. I was bumming about not having anything to work on and then this came along and now i have something to tinker with and have fun with for dirt cheap.
patgizz
10/23/10 12:48 p.m.
Start tinkering with em. Honestly i was in a little project car slump. I was bumming about not having anything to work on and then this came along and now i have something to tinker with and have fun with for dirt cheap.
challenge car here soon, you be on my team. good reason to go to florida next fall.
digdug18
digdug18 HalfDork
10/23/10 12:52 p.m.
Would this be in the ST class then for auto x?
CarKid1989
CarKid1989 Dork
10/23/10 11:17 p.m.
patgizz wrote: challenge car here soon, you be on my team. good reason to go to florida next fall.
Im in. Curious to see what the build is though. PM me?
jimbob_racing
jimbob_racing HalfDork
10/24/10 8:39 a.m.
digdug18 wrote: Would this be in the ST class then for auto x?
Try to run it in a carting class? I think the wheel base and track is too small for A mod.
fastEddie
fastEddie Dork
10/31/10 8:59 a.m.
http://jalopnik.com/5677496/lawn-mower-land-speed-record-returns-to-merica-where-it-belongs
Auto ADD
Auto ADD Dork
10/31/10 9:12 a.m.
I love the quote "It scared me so good"
priceless!
turboswede
turboswede GRM+ Memberand SuperDork
11/1/10 6:22 p.m.
slantvaliant wrote: Hmm ... how about a vertical Wankel?
No thanks I'm driving....
oldopelguy
oldopelguy Dork
11/1/10 9:18 p.m.
Usually the base of those is pretty much a pan with a bunch of holes cut in it. In HS we took one apart, flipped the pan upside down, and bolted everything from the suspension back on on the top instead of the bottom. It was like a 6" drop, had about 2" of clearance. Perfect.
Also there was a trick for using certain varieties of smog air injection pumps as superchargers for small engines. Not sure the specifics anymore, but if your google-fu is good...
RealMiniDriver
RealMiniDriver Dork
11/1/10 9:31 p.m.
CarKid1989
CarKid1989 Dork
11/1/10 10:57 p.m.
oldopelguy wrote: Usually the base of those is pretty much a pan with a bunch of holes cut in it. In HS we took one apart, flipped the pan upside down, and bolted everything from the suspension back on on the top instead of the bottom. It was like a 6" drop, had about 2" of clearance. Perfect.
maybe its late and thats causing me to scratch my head but can you explain that again. mostly from the suspension part down
RoosterSauce
RoosterSauce New Reader
11/1/10 11:26 p.m.
Those flat head mower engines are easy to m0d. I once shaved the head on a 3.5hp push mower and it only took me like half a beer. It must have been pushing 3.7hp after that. Removing the governor and adding a straight pipe helped, too. I bet the neighbors loved me so much that night.
JohnGalt
JohnGalt Reader
11/1/10 11:29 p.m.
RealMiniDriver wrote: Here's an idea....
Unbeknownst to me several of my greatest dreams and nightmares were just realized in NZ.
CarKid1989
CarKid1989 Dork
11/2/10 9:45 a.m.
Ranger50
Ranger50 Reader
11/2/10 10:22 a.m.
That is a nice stance. Looks like the axle could be flipped to put it back inline, if it's an old pulley on top arrangement.
Brian
GameboyRMH GRM+ Memberand SuperDork
11/2/10 10:36 a.m.
Hold on, the world speed record for lawnmowers is under 100MPH!?
Stick a turbo 'busa engine + transmission in there and make history
vEyaQZLCEC7KFWDcbHv7QzrCxGVICgKTabNOqe7PvAdCXxOZacVeXdcsWjtmztiI
