Curtis73 (Forum Supporter)
8/15/21 10:35 a.m.
A GY6 weighs 60 lbs with the CVT.  I wonder if it can operate without the CVT or if the case has integral parts.
Hopped up GY6 is 12-14hp, which could put 10 to the water through a jet.  Also, air cooled.
But is that any better than just dropping a 9.9 or 15 on it which weighs 75 lbs?  Plus, an outboard is easily removable for loading/unloading the boat in the van.
I'm just leaning so hard toward jet because of shallow water.  I've been on the river here with a "pitchfork" outboard.  The problem is that you're usually fine if you hit the pitchfork.  It's the repeated whacking on the lower unit that eventually rips a hole in it or just breaks it off.
8/15/21 11:05 a.m.
Now I'm going down the rabbit hole of lightweight engines that make good power and found DLE-222 222cc 4-Cyl Gas Engine with Electronic Ignition and Mufflers [DLE-222] | Airplanes - RC Planet
A 222cc 4-cyl two stroke that makes 22 hp and weighs 12 lbs.  Just a shame that it's $2000.
03Panther
03Panther UltraDork
8/15/21 12:17 p.m.
In reply to Mr_Asa :
And to Curtis:
Cool toy!
 I doubt shipping is worth it, but I'd be right interested in that 3.5. Or any smaller outboard. The 15-18 is gettin' a bit large, but wouldn't turn one down!
As said, do the jet drive! A outboard jet drive ain't as cool, but I think would be perfect. That 2 stroke would be fantastic, but that's a steep entry fee.
To both of y'all, I need a smoking' deal on a trolling motor, as well! This area is not the place for cheap boat stuff.
Toyman01 + Sized and
Toyman01 + Sized and GRM+ Memberand MegaDork
8/15/21 12:21 p.m.
That makes me all tingly inside.
8/15/21 1:18 p.m.
In reply to 03Panther :
You coming to the challenge?  Or know someone who can relay?  Make me an offer I can't refuse.  NADA says $500 but I wouldn't do that to you.
8/15/21 1:21 p.m.
Sooo.... anyone have a cheap/free jet ski?  I can't imagine wanting the weight of anything over 500cc but would entertain a 250 or 300 as well.
8/15/21 1:22 p.m.
In reply to Toyman01 + Sized and :
Do you happen to remember a guess on what your jet drive weighed with the motor?
03Panther
03Panther UltraDork
8/15/21 3:22 p.m.
Now cheap (non running) 'skis do seem to be available here, if they do not show up around there. I forgot the challenge was coming up soon. Doubt I'll make it this year either... same spectator problem... but ain't far off the trail!
captdownshift (Forum Supporter) GRM+ Memberand MegaDork
8/15/21 3:32 p.m.
That works with an outboard, not with a jetski swap...
Mr_Asa
Mr_Asa PowerDork
8/15/21 3:33 p.m.
Brother in law has two or three.  I can check price and displacement.
8/15/21 4:13 p.m.
The drive weighs less than 30 pounds. The engine is 70-80 at a guess but I didn't weigh it while I had it out. I would figure 100-130 pounds, all in including the bottom of the hull the engine and drive are mounted to.
8/16/21 10:21 a.m.
Good to know a ballpark, thank you.  That's heavier than I was hoping.  The 3.5hp I got probably weighs 30 lbs.  A 6-8 hp old school OMC is about 50-60 lbs, and a 9.9/15 is about 75 lbs.  Outboards are boring, but popular for a reason.
No Time
No Time SuperDork
8/16/21 4:25 p.m.
Just a "hold my beer" thought:
How about making it an airboat?
A rotax 377cc fan is about 80 lbs and puts out 35hp, since it's not an aircraft you could even go to a 440cc or 503cc. You might find some bargains this time of year.
Airboat thread
8/16/21 5:38 p.m.
In reply to No Time :
Ooooo.... Hold my beer.
8/16/21 9:56 p.m.
Then you can also use the air boat in front of the garage with either smoke or mist as a wind tunnel for challenge aero development.
8/17/21 9:50 a.m.
In reply to captdownshift (Forum Supporter) :
Just borrow a fog machine from the theater.
1SlowVW
1SlowVW HalfDork
8/18/21 7:55 p.m.
Fans are silly.
If you're not going with an obnoxious two stoke the next logical step is to go with a pulse rocket engine.
8/18/21 8:12 p.m.
Polite correction... Fans are inefficient, but just the kind of overkill and excess, which sounds like my kind of fun.
I don't think I would do it.  Hard to fit a 6' tall fan cage in a van, but it's like putting a lumpy-cammed big block V8 in a Nash Metro.  Which, by the way, I also approve of.
Rocket engines have that pesky problem of not being able to be shut off.  A turbine, on the other hand....
8/18/21 8:25 p.m.
I feel the encouraging must continue.
I never did anything useful with it but...https://grassrootsmotorsports.com/forum/build-projects-and-project-cars/the-next-project-gas-turbine-content/48381/page1/
This guy, on the other hand, is a genius with these things. https://rcdon.com/html/experimental_projects.html
8/19/21 9:17 p.m.
How are we not best friends?
8/20/21 5:08 a.m.
We are, we've just never actually met face to face. laugh
9/9/21 4:22 p.m.
11GTCS
11GTCS Dork
9/9/21 4:38 p.m.
I think yer kitty might be a touch asthmatic.  laugh  Tohatsu 3.5?
That’s all you need for a small boat like that but thanks for all the tangents.
RX Reven'
RX Reven' GRM+ Memberand UltraDork
9/9/21 5:37 p.m.
Polite, polite correction..."solid" rocket can't be shut off, a "liquid" rocket such as this hydrogen peroxide rocket can be throttled.
Let me save you the trouble of looking it up...you get about 120 pound seconds of thrust per pound of propellant.
Added later...
Just looked it up, static thrust for a boat propeller is about 19 Lbs per Hp. so you'd be burning about 1.58 Lbs. per second to equal the thrust of a 10 Hp outboard surprise
Dubbed Rocket Belts HydrogenPeroxide Powered Packs Can Editorial Stock  Photo - Stock Image | Shutterstock
9/9/21 9:02 p.m.
In reply to 11GTCS :
The kitty is a 4-stroke single cylinder.  It will always sound asthmatic.
It's a Mercury, so effectively yes... Tohatsu
k2Jf0iUZfvFaUyc6QAqxDHl3a3gadh6EMCS7DnBo1e25l5RKF33JojsX1AGZdeHX
