malibuguy
malibuguy GRM+ Memberand New Reader
12/20/17 1:26 p.m.
I'm sure we have people who have experience in this.
I bought a big Fisher woodstove used and I want to put it in place of my current fireplace.  It will be freestanding...however I want to have it pretty much in the opening of the fireplace.
It has a 8" outlet...I was thinking of getting a 90* and then fabricating my own adapter to go thru my existing flu.
We got a quote of doing a similar thing for $750, and thats with my Wife and I  providing and installing the fire board on the floor and me modifying the feet of the stove to sit about 1.5" lower to fit in the fireplace better.
Just seems a little high for essentially sliding the stove over and making an elbow.
Fueled by Caffeine
Fueled by Caffeine MegaDork
12/20/17 1:51 p.m.
sleeve the flu with stove pipe.  Use the double wall stuff and have it be our outside air intake as well as exhaust.
malibuguy
12/20/17 2:13 p.m.
Im not sure I follow.  The stove has air intakes in doors
RX8driver
RX8driver Reader
12/21/17 6:58 a.m.
Our home insurance required a certified installer and inspection when we installed an air tight insert into our fireplace. Would be a good idea to check with yours.
12/21/17 7:43 a.m.
Put a Barometric Damper in the flue system.  On windy days the weighted flap opens and closes so wind doesn't suck out the fire; more important it keep down drafts from shooting hot coals into your living room.
93gsxturbo
93gsxturbo Dork
12/21/17 8:21 a.m.
I would let the pros deal with it.  House fires suck and $750 is cheap in the long term.
iceracer
iceracer UltimaDork
12/21/17 5:49 p.m.
In reply to malibuguy :
That air has to come from someplace.
Streetwiseguy UltimaDork
12/21/17 8:24 p.m.
Insurance companies hate wood burning stoves.
rustybugkiller
rustybugkiller Reader
12/22/17 2:07 a.m.
Ive been burning since 05 and my insurance has been fine with it. All they asked was for professional insulation.
rustybugkiller
12/22/17 2:16 a.m.
You will want a SS liner down your chimney that is insulated. Also a block off plate at the damper. If done properly, flue fires are never a concern. Of course properly dry wood is a must. Mine sits for 2 years at least before use. I have two stoves, the fireplace insert runs constantly all winter and when I clean the flue in the spring I’m lucky if I get a half a coffee mug of flue dust. All because of proper install and dry wood
rustybugkiller
12/22/17 2:25 a.m.
Never saw the purpose for these. If you have the issues you mentioned, it’s because of improperly designed flue. Either too short, wrong diameter, or an obstruction near the flue. A properly designed system has no need for that.
SVreX
SVreX MegaDork
12/22/17 6:51 a.m.
Not sure I'm understanding the recommendations to line the flue.
This is a functional chimney in good condition, I assume. I pretty sure the $750 quote did not include lining the flue.
Toyman01
12/22/17 7:04 a.m.
This.
All you should need is an adapter from the stove to the flue plate in the chimney. I ran a Fisher as my primary source of heat for 10 years without a problem. It was almost too much stove for my house and climate.
Do keep an eye on buildup in the chimney. Running a throttled back stove will coat the chimney with soot. I would run a brush down mine ever fall.
RX8driver
RX8driver Reader
12/22/17 9:16 a.m.
As I recall from reading the manual for our insert, in the US the regulations only require a partial chimney liner into the existing, in Canada though, it requires a full liner, from fireplace to the outside. Seems to me like the full liner is the  better way to go for just a little more cost.
SVreX
SVreX MegaDork
12/22/17 10:39 a.m.
In reply to RX8driver :
Why is it better?  Draft is draft.
And it's not "just a Little more cost".  Chimney relining can cost $2500-5000.
That Canadian guideline has nothing to do with performance or efficiency.  It has to do with insurance companies limiting their liability exposure by forcing work to be done by licensed vendors to older systems.  It's an insurance policy for the insurance companies.
If it's damaged, it should be repaired. But if it ain't broke, don't fix it.
malibuguy
12/22/17 11:11 a.m.
The 750 was not to reline the chimney.  He said its not needed as mine is in good shape.   My chimney is much taller then the house with very little obstruction.
pheller
pheller PowerDork
12/22/17 12:42 p.m.
Just because I've been interested in this:
What does a good pellet or wood burning stove (do they make variants that can do both) installed in a house with very high ceilings run for professional installation?
Basically, my house is pretty cold, due to really high ceilings and a pretty small furnace. I've conflicting answers one whether my furnace is properly sized for the house. HVAC guys  of course say "it's too small we'll install a new one for $6,000." but guys who are too busy to actually do such an install say "it's a little small, but should be more efficient than a bigger one."
In addition to this, I've got lots of friends asking us "do you guy have a wood stove? We always wanted a wood stove. There is something so cool about wood stoves. You guys should have a wood stove installed."
So what I'm wondering is, in this cabin community of mine, could I sell my house a bit quicker with a nice cozy wood or pellet stove in the house?
RX8driver
RX8driver Reader
12/22/17 6:29 p.m.
It's not that the chimney needed to be rebuilt or anything, ours is a stainless flex pipe inside the old masonry chimney to make sure that the exhaust gas, ash and so on makes it all the way outside. This is for an insert specifically, replacing a standalone fireplace with an insulated metal chimney is different.
SVreX
SVreX MegaDork
12/22/17 8:47 p.m.
I understand.
A chimney (in good condition) does the exact same thing.
rustybugkiller
12/22/17 10:50 p.m.
Old chimney flues are too large for modern stoves and probably are not sound (safe). New construction would be different obviously.
You want the flue to stay as hot as possible until it exits the chimney. That’s why it should be insulated if it’s going to be a long run up a chimney. Prevents creosote
rustybugkiller
12/22/17 11:10 p.m.
$300 buys you 20’ of flex SS liner. Not sure why he would charge $750 to run a pipe from stove to the chimney without lining the chimney unless he’s lining his pockets.
Edit: Good advice can be found here: hearth.com
The taller the chimney the quicker it will cool and condensate causing creosote build up.
SVreX
SVreX MegaDork
12/23/17 8:04 a.m.
I understand there are more efficient ways to do it.  But a functional, good condition chimney does not need to be relined as a matter of general practice when installing an insert.
SVreX
SVreX MegaDork
12/23/17 8:06 a.m.
Because licensed tradesmen deserved to be paid, and earn a profit.  He is carrying the liability, licensing, etc.
BTW, I've never seen a 20' tall chimney.  indecision
dean1484
12/23/17 6:48 p.m.
My chimney is more than 20 feet tall over all. Two stories plus an attic and then five feet or so above the roof. I assume that is what he was talking about and not that it was twenty feet above the roof.
SVreX
SVreX MegaDork
12/23/17 7:47 p.m.
I meant I've never seen a chimney that was ONLY 20' tall.
That's not completely true- a single story with a chimney on the low side would usually make it, but generally, that's not a sufficient budget.
OwASXgUlx6wHkWzmcyiXICi9VhBJsacUVqlsIdFMhosd9CvHJGluR6XMr1zDbe8W
