ive been doing research and trying to find a seat that will fin in my 01 mitsu mirage coupe and im just trying to see if there are any of you out there that ran into this problem with smaller cars as well. i have checked recaro, momo, sparco, nrg and so on so i was hoping some of you guys that are a bit broader fitting into smaller cars. im 5'10'' and 300 lbs with a 48'' waist what ever insight you guys can provide will be much appreciated.
I have found the Corbeau FX1 Pro to be fat guy friendly. Even in normal width. Its available in a wide but it likely wouldnt fit in your car.
https://corbeau.com/fx1-pro.html
The answer is OMP TRS-E XL - largest FIA-rated seat out there for under $1K.
I have one bolted into a Honda Civic. I'm 6'4", about 330 and I have a 46" waist.
Is this going to be a street car or a race only car? I'm your size and I have a 17" kirkey in my track Miata. It took a little bit of massaging of the trans tunnel with a sledge hammer, but it fit. With the padding it is decently comfortable. I wouldn't want to drive 2 hours in it, but 20 minute sessions or 30-45 minutes to the track are not too bad.
logdog said:I have found the Corbeau FX1 Pro to be fat guy friendly. Even in normal width. Its available in a wide but it likely wouldnt fit in your car.
Yep! I'm 5'-10", 275, and a 44" waist. I'm also fairly broad shouldered, though I carry more weight in front than I do in the hips and butt. The FX1 Pros are very comfortable for me, and fit in the Miata.
