I built a teak helm for my boat and it's time to reassemble. Although it's not necessary, the better I can seal the area around the steering shaft the less likely I am going to get corrosion/water inside my center console. I was thinking of getting a thick piece of rubber, and cutting it to washer size so that i could kinda wedge it between the wood and the stainless steel top plate I made. Any other ideas?
Sounds good to me. Beautiful wood refinishing. How about a picture from afar so we can see your work?
As you have that large chromed plate to cover most anything up. How about This?
Ovid_and_Flem said:Sounds good to me. Beautiful wood refinishing. How about a picture from afar so we can see your work?
Good idea, I'll make a build thread and post here.
Datsun310Guy said:We have 1/4” thick neoprene circles at work. It might work?
That would probably work great, I'll see if I can find any.
Fueled by Caffeine said:Would neoprene wear out in that case?
can you find a rotary shaft seal in McMaster Carr?
If it did wear out I think it would take a while. like I said it's not critical that it's water tight. Just need to minimize water from a direct hit from the hose when cleaning. Otherwise it shouldnt get very wet.
Rotary shaft seal would be cool to incorporate but I would have to cut the wood/finish to get it to work. Maybe next time!
