NY Nick
NY Nick GRM+ Memberand SuperDork
5/8/24 9:11 a.m.
In reply to ShawnG :
I will try to shift with no clutch and rev match first, disconnecting the clutch brake means R&R the trans again, not the end of the world but I would like to not to.
wvumtnbkr
wvumtnbkr GRM+ Memberand UltimaDork
5/8/24 9:24 a.m.
Is there a pilot bearing?  If so, is it stuck in the crank and stuck to the input shaft?
NY Nick
5/8/24 9:49 a.m.
In reply to wvumtnbkr :
I don't think there is. When we removed and reinstalled it went in and out easily, when we took it out this time we didn't touch the clutch so I don't really know what is in front of it but I think it's just the spline that angages thorough the clutch and no bearing.
ShawnG
ShawnG MegaDork
5/8/24 7:02 p.m.
Honestly, I think this thing would operate well without the input shaft brake.
I think No Time has it right. It's actuating too soon and preventing a shift.
Those sliding gear transmissions need to be moving for everything to slide into place.
There's a trick to driving them and you pretty much have to float the gears into place even though you have the clutch disengaged.
I doubt you'd use the input brake feature unless you were intimately familiar with that transmission from many hours of driving, AND in a really big hurry to make the gear change.
No Time
No Time UberDork
5/8/24 10:34 p.m.
The other thing you could do is disconnect the driveshaft, like Shawn said, and try turning things from the output shaft.
- check drag in neutral when turning the output shaft to get a feel for the drag in the transmission
- Start with the engine off, the trans in gear and the clutch pedal released, try rotating the output shaft and someone slowly depresses the clutch pedal. You should be able to confirm there's a point where the clutch is released but the brake isn't activated. This should be more subtle than trying to watch with the engine running.
- when the clutch releases you can feel for any binding or inconsistent drag that may indicate a clutch or pilot bearing issue.
- also feel for a stuttering feel when rotating things with the clutch pedal depressed. I'm not saying it's the case, but I've seen clutch disks installed with the wrong side towards the engine. That can result in contact between the hub and flywheel/flywheel bolts, not necessarily enough to prevent release, but enough drag to make sifting difficult.
DarkMonohue
DarkMonohue GRM+ Memberand SuperDork
5/11/24 9:57 p.m.
This is way outside my already feeble realm of knowledge and too interesting not to follow.
Is the clutch brake intended for use when the truck is rolling?  If my sources are correct, modern trucks use it only to stop the input shaft when the truck is stationary so that a gear can be selected.  Maybe the REO is different but it seems safe to assume it's the same idea - use it to pick a gear when the truck is stopped, not when shifting between gears.  Very open to correction here.
If the above is correct, can you get the rear end up on jackstands and let the engine idle with trans in neutral?  You could try selecting low gear and doing a few mock takeoffs while someone else observes.  It might help confirm where in the pedal travel the clutch and the clutch brake are engaging and disengaging in relation to each other (it seems likely that you'd want the clutch fully disengaged before the clutch brake begins to grab).  It might also be a way to verify that the clutch is actually disengaging fully, period.
Going a different direction, how quickly does engine speed drop when you release the accelerator to shift gears?  If engine speed does not come down to match the next gear, selecting that gear might be difficult.
NY Nick
5/17/24 1:40 p.m.
Here is the latest update.
After sharing the video, pictures, and the whole saga with Fort Wayne Clutch ( https://fortwayneclutch.com/part-category/clutch-friction/antique-obsolete-clutch-kits/ ), they seem to believe that there is a problem with the pressure plate. The clutch was R&R'd before I was involved in this deal so I don't know what may have happened then, apparently it has had trouble shifting since then, although it could shift just not well.
So we are going to pull the trans again, and the clutch and pressure plate and see what we got. I will give an update when we get under it and start pulling things apart.
Thanks for the input and suggestions!
ShawnG
ShawnG MegaDork
5/17/24 5:39 p.m.
Wait... It's a leather cone clutch?
Jeez, I could have walked you through relining that on the phone. I've done them before, There's a couple tricks to ensure that they seat and release properly but usually, they're a breeze.
Has it been oiled?
They can stick together bad if left to sit for a long time without the pedal being held down with a board.
NY Nick
5/17/24 7:16 p.m.
I don't think it's a leather clutch. That's just the home page of their vintage section. I am told that Fort Wayne clutch is very experienced and knowledgeable about the old stuff.
ShawnG
ShawnG MegaDork
5/17/24 7:25 p.m.
In reply to NY Nick :
They are, they've got a great reputation. I'm sure they'll get it figured out.
NY Nick
12/26/24 2:06 p.m.
Well the next chapter of the saga happened this morning. We ran the truck through the parade season, in first and second gear with no shifting while moving. Because the parade season ended late by the time we could all get together to work on it it was today! Great day to work on things in an I heated garage. It was 11 degrees when I was driving there. But we had a couple of propane salamanders so it wasn't too bad.
took out the trans and the bell housing, clutch and pressure plate. There was one broken spring on the pressure plate, one of the old timers is taking it home to measure flatness. Then it is off to FWC for an inspection and rework.
Taking it isn't too bad of a job. It was less than 3 hours with an 80 year old me and my son working on it. I lost a hold on the bell housing when we were taking it out and it caught me in the face. I look like a boxer after a bad fight night!
NY Nick
12/26/24 8:51 p.m.
Pics of clutch
ShawnG
ShawnG MegaDork
12/26/24 10:57 p.m.
Looks like the lining is all there and in good shape.
If there was a broken spring, I'm betting that's related to the release issue.
NY Nick
1/11/25 4:43 p.m.
Parts are at Fort Wayne Clutch they needed a dimension so I grabbed them this morning. Distance from flywheel surface to where the assembly bolts up. I took it at 8 places.
Min- 2.684”
Max- 2.694”
Ave- 2.691”
Hopefully this fixes things. No help needed at the moment but I figured I started this thread I should update and see it through.
ShawnG
ShawnG MegaDork
1/11/25 5:40 p.m.
I'm sure you'll have it Back on the Road Again in no time. Keep Pushin' the updates because I Do Wanna Know how it turns out.
I'll see myself out...
NY Nick
2/22/25 1:55 p.m.
Well today was reinstall (as much as we could) day.
We got the clutch in, pressure plate, bell housing, transmission, shifter, and driveshafts. We still have to hook up the emergency brake, and the floorboards. We also put a screw on oil filter and need to put the oil back in the engine and the transmission hopefully we will test it out this week.
Here are some pics of the excellent work from Fort Wayne Clutch and of the install. The little pink blocks are there to protect the springs on install, you have to put it in first and then take the blocks out. Apparently this was not done last time and it could be the root cause of the problem.
NY Nick
2/22/25 1:55 p.m.
NY Nick
2/22/25 1:56 p.m.
NY Nick
2/22/25 1:57 p.m.
NY Nick
2/22/25 1:58 p.m.
ShawnG
ShawnG MegaDork
2/23/25 12:19 p.m.
Looks like top quality work!
Glad to see this coming along.
NY Nick
2/23/25 1:53 p.m.
Thanks! I'll keep updating until it's done. Maybe in 5 years someone else will have this problem and this will be a reference for them.
Agree the work from Fort Wayne was awesome.
NY Nick
2/23/25 4:46 p.m.
Oh so one little story that could help anyone working on a rare thing.
First a little background. A friend of mine owns a garage, small private place called "Harry's Brakes". Harry will work on some weird stuff that most people won't. He is set up to do brake relining and does a lot of really old stuff. The local fire department has an early 30's American LaFrance fire truck and it needed brake work, Harry took it in and found it needed a master cylinder, he took it out sent it to be rebuilt and it was lost in the mail (I honestly don't know if it was FedEx or UPS or USPS). The thing is gone and there are none that anyone can find, this truck has been on a lift in his shop for months now as they try to find a replacement. Side note, Harry is a Shriner with me so it's interesting that this old fire truck is in his shop and we are working on this other old fire truck.
We shipped that clutch assembly to FWC and it was ~$40 from Fed Ex the return freight was ~$80. The guy that was handling the comms asked why the difference and FWC told him that so many of these old impossible to replace parts were getting lost in the mail. They put $7,500 of insurance on it (that's why the cost difference). They said that once they started putting that much insurance on these parts they stopped getting lost in the mail. That $40 could save an unbelievable amount of hassle.
7kU8EKLtPh7ZP6wIR1NmMAStGhRRJf5pBuzsl75nAmRArwGA1cDLFBccrk2LKnwf
