gszczyrbak
gszczyrbak New Reader
5/28/21 12:10 p.m.
Gonna do some rust removal and repaint my rear subframe. How do you all mask over threaded holes that bolts will go back in eventually?  I'm thinking stuff some aluminum foil in them?
Mr_Asa
Mr_Asa UberDork
5/28/21 12:13 p.m.
I used to do that, now I don't care.  I just chase the threads with whatever tool is appropriate.
If you have to, not a lot works better than an old bolt
obsolete
obsolete GRM+ Memberand Reader
5/28/21 12:17 p.m.
I've stuffed wadded-up painters tape into stuff like that before, but I usually have enough spare bolts and studs around to just thread into the holes to keep the threads clean. That's the best way IMO.
Run_Away
Run_Away GRM+ Memberand Dork
5/28/21 1:01 p.m.
Earplugs
iansane
iansane GRM+ Memberand HalfDork
5/28/21 1:01 p.m.
You don't have the ubiquitous spare bolt bucket?
APEowner
5/28/21 1:38 p.m.
I use silicone powder coating plugs for smaller fastener holes.  For something like a subframe I'd probably just paint them and then blast the bolts in with an impact gun.  If a bolt started funny I'd pull it back out and run a tap in.
californiamilleghia
californiamilleghia SuperDork
5/28/21 2:49 p.m.
there is a company called Cap plugs  that made the ones we used .
They have all sizes if you are doing production work
LLdbtVWbZRgWgDRcPCOLCLU17fUBteJ4d9XUjjWL4QtUZ8VCMs7Jrf2qUj5u98VO
