Suspension bushings: Small yet important pieces of your suspension system
David S.
By David S. Wallens
Apr 10, 2022 | suspension, Handling, Bushings | Posted in Shop Work , Suspension & Handling | From the Nov. 2013 issue | Never miss an article
Photography Credit: Kevin Adolf
Tires, springs, shock absorbers and anti-roll bars get a lot of attention, but what about those unassuming bushings–you know, the little blocks of rubber tasked with locating all those suspension components day in and day out? Perhaps it’s time to think about them.
Just about every mass-produced car has been delivered with rubber bushings. Rubber does a fine job of locating suspension pieces without transmitting too much noise, vibration and harshness. However, there’s one small problem with these rubber bushings: They don’t last forever. Over time, rubber can crack, split and deteriorate.
Plus, rubber isn’t the toughest material ever made. If you’re hurtling around the track, would you rather have your suspension parts located by tough, firm bushings or ones that are a bit squishy?
The aftermarket, as usual, has come to the rescue with replacement bushings formed from polyurethane, a stronger, moldable material.
When to Replace
“You should think about your bushings [as] a wear-and-tear part,” explains Michael Santa Cruz, director of marketing for urethane bushing maker Energy Suspension. If a handling issue, like poor control or accelerated tire wear, isn’t tied to the usual suspects–springs, tires, alignment and shock absorbers–then perhaps the bushings have sheared, worn out or simply given up the ghost. Basically, the suspension elements are moving in ways they aren’t supposed to because of a bad bushing.
First, do a visual inspection. Are the bushings still there and in one piece? Then do a dynamic test. “I kick the tire backward–seriously,” says Ground Control’s Jay Morris. If the tire moves, then perhaps the bushings are no longer doing their job.
While bushing replacement is usually associated with older, higher-mileage cars, that’s no longer always the case. Michael Santa Cruz explains that today’s heavy, high-horsepower cars can quickly shred the stock rubber bushings. The new Dodge Challenger, he notes, is on that list.
The technological aids found on a lot of these newer cars can help diagnose a bushings issue, too, he continues. Is the ABS or stability control kicking in sooner than expected? If so, perhaps a compromised bushing is allowing something to move outside its planned range.
Photograph Courtesy Energy Suspension
Too Tough for Street?
“The current perception of urethane bushings–at least here in the United States–is that they are hard to install, equate to harsh ride, produce embarrassing squeaks, are a PITA to regrease/maintain, and that the resulting suspension performance and NVH are equal parts tradeoffs,” says Tom Phan of bushing maker Whiteline USA.
However, he notes, modern manufacturing techniques and design can cure those issues. Features like pin-holing, tapered contact faces, scallop voiding and pocket knurling can provide the desired performance without harsh degradation of NVH levels.
Energy Suspension’s Michael Santa Cruz adds a little perspective: “What’s harsh to you is soft to me and vice versa. It’s like when you lower your vehicle: It looks better, handles better but doesn’t ride better.”
The GRM staff’s experience? Generally polyurethane bushings create more NVH, but rarely is it objectionable. If you want a factory ride, yes, stick with rubber. If you’re redoing your suspension and want to sharpen the handling, then upgraded bushings will often deliver as promised.
Like what you're reading? We rely on your financial support. For as little as $3, you can support Grassroots Motorsports by becoming a Patron today.
Join Free Join our community to easily find more suspension, Handling and Bushings articles.
Comments
msterbeau
msterbeau New Reader
8/3/20 10:09 p.m.
Next step: Spherical bearings and rod ends.  :-)
wspohn
wspohn Dork
8/4/20 10:49 a.m.
The reason for staying with rubber is that the solid bushes (poly, Delrin etc.) rotate in the suspension components, need some sort of lubrication, and wear themselves as well as the suspension bits they run in.  The rubber don't move, they just flex (and of course eventually wear out that way)
The reason for not staying with the old style rubber bushes is that it seems that it is becoming more and more difficult to source decent rubber today. In the old British car world, much (most?) of the rubber bushes come from China or India and while one batch may be great the next may be crapola.  Owners are finding that they are changing them again after less than a year on the car when the OEM bushes would last years.
The market is strange - I would gladly pay 3 or 4 times as much for bushes that would last a long time or chrome bits that didn't need to be stripped and rechromed out of the box if they are to last any time at all, but the vendors tell me that people opt for the cheapest part (and then bitch when they get what the paid for).  (Hint to MG owners - never use anything but the MGB V8 'metalastic' bonded rubber/steel bushes - they still seem to last well).
Given that, I think that the solid bushes will gain a following, as they offer both bragging rights and reasonable longevity (haven't seen any complaints about the solid bush quality control, but maybe I haven't noticed).  Just remember that bushes like that don't make their wear noticeable until it is great enough that it may also require replacement of some suspension bits (I am assuming that no one ever checks anything under their car that doesn't make noise).
ProDarwin
ProDarwin UltimaDork
8/4/20 10:56 a.m.
I've never had poly suspension bushings create an objectionable amount of NVH.  But in my experience they wear out much quicker :(
Unfortunately, for many vehicles, replacing the rubber bushings is nearly impossible, or stupid expensive, or NLA.
Tyler H (Forum Supporter)
Tyler H (Forum Supporter) GRM+ Memberand UberDork
8/5/20 1:45 p.m.
Polyurethane bushings are often misapplied.  It's not NVH, it's the fact that it takes a 20 ton press to get the OE bushing out, and then you can just push a greased up poly bushing in by hand?  There is a lot of slop there with poly bushings.  They float around on-center and then the take-up is abrupt because they're less compressible than rubber when corner loads build.
If a suspension component moves through more than one plane in it's travels, don't put a polyurethane bushing in it.  They're not good in control arms and trailing arms.
Just because it's aftermarket and it's red doesn't mean it's an upgrade.
MrFancypants
MrFancypants Reader
8/5/20 6:48 p.m.
If the replacement bushing isn't precisely the correct size doesn't that suggest a manufacturing or design issue? I'm fortunate enough that I was able to replace my stock, void filled control arm bushings with solid rubber bushings from a performance model from the same manufacturer. The new bushing was rubber encased in a metal sleeve and with some grease it went in so easily I could have pushed it in by hand (I used a hammer and a block of wood).
Regarding trailing arms....  I don't see why a poly bushing with a metal sleeve through the center and washers on the outside can't work. No twisting forces would be applied to the poly because of the sleeve.
MrFancypants
MrFancypants Reader
2/13/21 9:03 p.m.
I answered my question by installing the parts (poly bushings in trailing arms).  There's zero noise from the poly bushings because there's no actual friction between the bushing and anything else; the bushing exists to fill a void.  Just as with the stock rubber piece that was there, there's a metal insert within the bushing that the bolt goes through to secure the arm to the chassis; so it's metal to metal contact.
Handling is improved more than I thought possible; conceptually I understood that toe deflection at the rear would impact how the car turns, but the most noticeable change is how much steering accuracy and response is improved.
I'd have been perfectly happy to use solid rubber instead, but as far as I can tell this isn't a thing that exists.
350z247
350z247 Reader
2/14/21 1:12 p.m.
In reply to MrFancypants :
Definitely agree on the steering improvements. I replaced every single bushing on my R53 Mini with poly bushings and any other wear point (ball joints, tie rods, endlinks, etc.), and the biggest difference I noticed was the steering. The rest of the handling and ride didn't really seem to change much, though.
AENfor43
AENfor43
7/30/21 4:19 p.m.
Some of these comments in this article are Good, Bad & just downright Ugly.
I have worked with Energy Suspension for 12 years and now with PROTHANE for 6 years, so I know what I am talking about.
Companies that manufacture performance urethane/polyurethane vehicle suspension bushings exist for several reasons: 1)- to make some money & provide jobs 2)- to provide an alternative to rubber bushings that often wear out soon 3)- to supply automotive enthusiasts with an improvement in bushing and suspension motion control. The last one is really important to GRM readers! Not all bushings and producers are the same as far as proper engineering of the products. Just as that there are good vehicles out there and there are bad. Most of these urethane/polyurethane companies recognize the need for firmer durometer bushings to really help with maintaining important alignment settings under high G-forces enthusiasts demand (motion control). And, there are many, many levels of durometer firmness bushings, specifically chosen for the location of the suspension that these companies select. Two examples: Sway bar end links are the firmest, to improve vehicle roll control enthusiasts demand. On the other hand- tie rod boots are very soft, to hold in rod grease. Other areas of the suspension get different durometer bushings and mounts, such as motor mounts, trans., drivetrain, etc. And on and on. Properly installed, and many times easier to do so than stock rubber replacements, they will not squeak. Use the grease that come with the bushings!  Don’t forget, for the most part, professional race cars employ metal & hard bushings to maintain control. Way too much for street use.
Thank you!
Number1Gaza
Number1Gaza GRM+ Memberand Reader
7/30/21 10:31 p.m.
In the true GRM spirit of things, what prevents the budget conscious (challenge or similar) builder from taking a stock bushing with rubber surrounding a steel sleeve, cutting out the rubber, and replacing it with polyurethane?  Wouldn't that mostly accomplish the same thing as buying a premade poly bushing?
 I know this is done to engine mounts all the time but wouldn't it accomplish the same thing in bushings?
*note:  I actually tried this on front lower control arm bushings but without cutting out the rubber.  It doesn't work.  The movement of the bushing just pushes the poly right out.  But in theory if all the rubber was cut out the poly couldn't be pushed out; it would be larger at both ends than in the middle.
frenchyd
frenchyd UltimaDork
7/31/21 12:02 p.m.
Rubber is fine for the street. But my solution for the race track is to use the odds and ends of aluminum.  Cut it in half. Drill a hole at the split line just a tiny bit smaller  than the bar. If you don't have a ream the right size wrap a piece of emery paper around the bar and slowly work it to the exact diameter.  Then on either side of the bar drill holes to match the bolt pattern of the sway bar mount. One final task,  drill a tiny hole to push grease around the bar and put a grease nipple in to grease the bar.
re-drill  it bigger or make another set.
Mounts made this way will take stock bars or big tubular racing sway bars.
VfiDYSshVVwrntgGGAPFJPo9Jw3tlT2pwxwpzigHmymiss7gjVVVEgeQ0uZ6CEnm
