Suspension mods are one of the
first things we enthusiasts delve
into when looking to improve the
performance of our cars. And we don’t
do it alone: We decide on parts and a
plan of attack with help from dozens
of influences. Other owners of similar
vehicles advise us, whether in person or
on Internet forums. The websites and
magazine ads of parts retailers, with
their dazzling pictures of shiny wares
and astounding claims of performance
increases, also get our credit cards itching.
But does all this information add up
to a suspension setup that meets our
goals? Some problems are obvious, but
others hide themselves well. Here are six
common suspension pitfalls that may be
holding you back.
1. ANTI-ROLL BAR BIND
One of the least expensive and most satisfying suspension
mods involves replacing the wimpy factory anti-roll
bars with some beefy aftermarket units. It immediately
makes the car feel tighter and cuts body roll substantially.
Dynamic camber is also reduced, adding more contact
patch in the corners for more grip.
Perfect, right? Well, not for long.
Anti-roll bar manufacturers typically use urethane frame
mounts to provide a very crisp response, but this creates
a bearing surface that eventually wears out. To avoid
early complaints of knocking due to wear, the provided
bushings are almost always too tight when first installed.
Sure, you can lube them up to reduce some of the
offending stiction, but the grease quickly gets pressed out,
allowing the bar to bind. This, in turn, provides an infinite
roll resistance at that end of the car that will absolutely
destroy the handling.
SOLUTION: Easily fix those common D-shaped antiroll
bar bushings by grinding some material off the flat
portion of the bushing or by placing a washer under
one or both sides of the saddle bracket. For sure, grease
them periodically.
2. BOTTOMING OUT
Race cars sit nice and low to the ground, so a slammed
suspension must be good for your car, too, right? Certainly
a lower center of gravity pays dividends in reducing
weight transfer and the associated body roll. This keeps
all four tires working at higher rates of efficiency and does
improve handling. Plus, it just looks right.
But there is a dark side to slamming, one that emerges
when the car constantly bottoms out its suspension–
usually unbeknownst to the driver. Riding around on the
bumpstops under cornering loads can cause all manner
of unusual handling.
Your low-powered Miata may be wonderful on corner
entry but suddenly push like a pig in the middle. Or
perhaps it gets all loose at corner exit as the rear compresses
too far, allowing all the weight to transfer to the
outside-rear wheel. That’s not too much power causing
the wheelspin–it’s too little bump travel.
Likewise, we’ve all seen the extreme case of a slammed
car making like a pogo stick as it rides around town on
the undamped, high spring rate of its bumpstop rubber.
SOLUTION: The answer is to jack up the car, remove the
springs, and run the suspension through the entire range of motion without them. Verify that your bumpstops hit just
prior to a metal-on-metal encounter between suspension
pieces. Trim or stack bumpstops as necessary.
Next, reassemble the suspension, but place a zip-tie
or O-ring on each shock shaft so you can easily monitor
suspension movement. Drive around to see whether your
suspension bottoms out, and adjust the ride height up or
down accordingly.
3. EXCESSIVE BUMPSTEER
There is another, more insidious side effect of lowering.
Most production automobiles are designed to operate with
a wide range of suspension travel, and to have benign
characteristics within that range. Lowering a car takes it
out of that range and many times puts it into a zone where
the suspension geometry does all kinds of wacky things.
Massive toe changes can occur with the slightest up or
down movement. Even worse, body roll can cause the car
to toe in or out. Think about a car whose rear wheels toe
out as it rolls into a turn.
SOLUTION: Figuring this out with an
adjustable coil-over suspension usually only requires about an hour on an
alignment rack. Simply take alignment measurements as
you raise and lower the suspension in half-inch increments.
If you’re careful, you can also do this at home with a tape
measure or toe plates.
With these curves in hand, you can figure out what’s
going on at each end of the car regarding ride (both sides
up and down) and roll (up one side, down the other).
How do you fix things that are out of whack? For most
production cars, the only thing you can do is reduce the
effect by limiting the suspension movement through stiffer
springs–and with matching shock valving, too. Alternatively,
you can pre-compensate for factors like instability
from excessive dynamic rear toe-out by using a large static
toe-in alignment setting.
4. NON-OPTIMAL ALIGNMENT
Speaking of alignments, what’s yours? You’ve seen the
thread a million times on message boards: “Need the best
alignment specs for so-and-so car.” Sometimes the original
poster will also include a list of the car’s mods.
Next, a bunch of people chime in with all kinds of tribal
wisdom. Is it good advice? Well, maybe. It depends on
how close your car’s complete setup is to the ones those
guys used to come up with their alignment recommendations.
It also depends on your desired purpose for the car.
If you’re competing, the grip level and turn configuration
of the courses or tracks will also have a huge influence
on optimal settings.
SOLUTION: We’ve detailed the testing process before
in our “Dialing In” article, which ran in our November
2009 issue.
The short of it is that you figure out optimal camber with
a skidpad and a watch. Toe is determined using a slalom and an oval. Those setups from the boards may be good
ballparks, but you must test to find the right settings for your
car and your situation–especially when you consider the lowering
geometry and bumpsteer pitfalls we discussed earlier.
5. WORN/BROKEN PARTS
All of that setup work goes right out the window if the
adjusters slip under load or the attachment points are
oblonged or cracked. Many of us are flogging older cars,
and some of their parts may be far from new. As a result,
it doesn’t take much movement to deliver toe-out or positive
camber during high-g corners. Sometimes this slip is
even accompanied by an audible clunk or snapping sound.
SOLUTION: New factory adjusters installed with threadlocking
compound are cheap insurance. Paint marks can
serve as indicators of movement.
Plenty of other worn suspension parts cause handling
headaches, too. We’ve wasted a whole day of skidpad
testing because of a loose upper ball joint. Rock the wheel
aggressively to check for this issue.
Bad tie-rod ends can cause dynamic toe, as can worn
internal steering rack parts. Easily check these by rocking
the steering wheel with the vehicle at rest. And bad wheel
bearings will do weird stuff to camber, toe and even your
brakes. Again, rock the wheel to check.
Finally, check those suspension bushings, especially if
you’ve replaced them with aftermarket urethane or Delrin.
Delrin units typically require yearly maintenance: Disassemble,
clean and re-lube. If they aren’t maintained, rust
can creep in, causing bushing bind and a host of unusual
handling behaviors. Consider using grease fittings.
6. TOO MUCH SHOCK VALVING
Damping your new lowering springs properly will likely
require more valving from your shock absorbers. That
said, one size does not fit all, and “too stiff” is just as bad
as “too soft.”
Certainly, stiffer feels better. Your vehicle becomes
super responsive to every input and totally connected to
the road–that is, right up until it encounters a washboard
surface and chatters right off the road. This is an extreme
example of what’s going on constantly when the valving
is too stiff: loss of grip. There is a compromise between
proper control of the spring rate and suppleness over the
road or track surface.
SOLUTION: Optimal valving can offer both control and
comfort, but it may require a custom re-valve to achieve.
Off-the-shelf shocks can deliver the desired performance,
but only if they’re used in the situation they were designed
for. This includes the type of activity (track, autocross, street
use) and the aggressiveness of the rest of the car setup.
The more you optimize a component for one type of use,
the worse it is at other uses. Shocks are the poster child
for this concept.
