The most versatile race car is a Mack truck?
J.A.
By J.A. Ackley
Jan 12, 2025 | Mack Trucks, Mack, Mackvader | Posted in Features | Never miss an article
Photography by J.A. Ackley
What’s one of the most versatile vehicles ever made? A Mack truck.
It didn’t make your list, right?
At the helm of the 13,000-pound Mackvader, Mike Morgan has entered his 1998 Mack CH in several forms of motorsports: road racing, autocross, drag racing, oval track racing, top speed challenges and even drifting.
It’s like an old muscle car,” Mike says. “You drive it [into a turn], it rolls a bit, you get it to slide a bit, and then you gas it out of the turn. That’s how the truck is, but it’s better.”
Origin story
None
Mike dabbled in motorsports throughout his life, including autocrossing and road racing a Porsche as well participating in drag racing. However, when he heard of ChampTruck, a new road racing series for semis, the diesel mechanic wanted in.
“We traded two trucks for two halves of a truck,” Mike explains. “Some companies, when they’re done with a truck, they’ll cut them in half. It was cheaper to get two halves, and I’d get exactly what I wanted.
“For the front half, I found what I wanted for the frame, cab, engine and front axle. For the back half, I found the rear end I wanted with the gear ratio I wanted. Instead of trying to fight to get exactly what I wanted, I spliced it together.”
With parts in hand, Mike went to work.
“I put it together in a carport,” Mike continues. “The truck hasn’t seen a shop until last year. It lived in a carport and then a 130-year-old barn. We had cows walking around. We had chickens up in the truck. It’s a true barnyard build.”
Under the hood
None
To propel Mackvader, Mike installed a 11-liter Mack MP7 diesel engine mated to a Mack five-speed manual. He added a variable-geometry turbo from a 16-liter Mack engine. Mike typically uses about 100 psi of boost.
“It’s the same engine you would find in a garbage truck,” Mike says. “I figured if a garbage truck driver could beat the ever-living snot out of it all day long for years, that’s the engine I want.”
He runs the engine up to 3000 rpm. That may not seem high to most racers, but for a big-rig truck it’s quite a bit. For Mike, that’s about the limit to his comfort level.
“I don’t run a scatter shield on the transmission,” Mike says. “There’s a lot of mass in [the drivetrain]. I don’t want to see a clutch or flywheel come through the floorboard. I still want to live a long life.”
Turbo lag? Nonexistent.
“On a road course or a circle track, when I come up to a turn, I typically use the engine brake,” says Mike. “The engine brake pre-spools the turbo. The whole time the engine brake is going, it’s building up boost. So when I’m ready to exit a turn, you get back down on the pedal and get instantaneous boost.”
The engine combination makes 900 to 1000 horsepower–and 3000 lb.-ft. of torque. That’s not a typo.
“It sucks you back into the seat,” says Mike. “It’s meant to pull an 80,000-pound load.”
Setting Up a Truck–Part 1
None
Mike says his truck uses stock components–and he keeps it simple. For example, he didn’t opt for an air suspension because if a standard suspension “is good enough for racers in Europe, it’s good enough for me.” However, don’t mistake this as the same truck that came from the factory.
“There’s a lot of old-school racing tricks that you can do,” Mike says. “It’s the same things you do to a car, just on a bigger scale.”
Let’s start with the rear.
“The rear axle, it’s adjustable,” Mike explains. “So we can turn the axle sideways a little bit and adjust pinion angles, drive angles and spring rates. We’ll push it back–about an inch to an inch and a half–to give it rear steer for turn-in on an oval.”
The shocks and springs aren’t that trick, he admits. “I got one of the cheapest shocks you can find,” he says. “It originally came with eight leaves, but now I got it down to one and a half leaves to get the correct spring rate. You start by cutting a chunk of spring out at a time–there’s no machine to determine the spring rate.”
Mike’s most common adjustment involves tweaking the tie-downs to clamp the ends of the leaves while also adding or increasing wedge. “To get this truck to turn on a road course or an oval, the tie-downs help with that,” says Mike. “You got to get the inside-rear tire just a little bit off the ground. That will help that tire break traction and get the truck to turn.”
Setting Up a Truck–Part 2
None
As Mike says, the truck’s just a big car–and caster, camber and toe are all important. But to change camber requires some creativity.
“We have tons of caster–up to 25 to 30 degrees,” Mike says. “If you push an axle far enough, when you turn the wheels, you’ll create camber. We also bend the axle to a certain degree to create more camber.”
[What Is Camber, Caster and Toe? | Handling Basics]
Mike uses an anti-roll bar on the front just like you would on a Miata–but his is a lot bigger.
“We have a sway bar up front, with a link on the left-front where we can pull down against the sway bar and change its rate,” Mike says. “We also got limit straps to limit how much roll we have in the front end.”
To stop 13,000 pounds of truck, Mackvader has brake drums on the rear and water-cooled 18 1/2-inch disc brakes up front. As with a car, Mike can use the brake balance booster to adjust the bias, and he typically uses more rear brake on a road course.
The Beginning of Mackvader’s Career
None
Mike debuted the truck in 2014 in ChampTruck.
“We towed to the first ChampTruck race, with a Dodge 3500 and a gooseneck trailer, all the way from Nashville to New Jersey [Motorsports Park],” Mike says. “I was the only one hauling their truck with a Dodge pickup. Everyone else had Class 8 semi-trucks hauling theirs. I just wanted to be a part of it. I expected to just race one or two races that season.”
Those plans quickly changed.
“I won everything that weekend in New Jersey,” Mike recalls. “We kept on going. The next race was in California. I had never even been to California.”
The more Mike raced, the more he won, but the success didn’t stop him from trying to improve.
At an event in Colorado, 10-time champion of the British Truck Racing Championship Stuart Oliver came stateside to try the American equivalent of what he raced across the sea.
“I said to Stuart, ‘Drive my truck. Tell me what to do to make it better,’” Mike says. “He took it for one ride around the track and came back and said, ‘How do you drive this thing?’ The whole rest of the night, he and his crew are up all night partying. I’m there sipping a beer and listening to every word he said. I used that knowledge for the rest of the season and just whooped everybody’s ass.”
That incredible run led not only to the 2014 ChampTruck championship but also the 2015 title.
The series was then sold and turned into the Bandit Big Rig Series, and the action moved to ovals. Mike continued to win races.
A Mack of All Trades
None
Mike doesn’t limit Mackvader to road courses or ovals. Anything is fair game.
For example, Mike drag raced Mackvader against a 2021 Ford pickup before a Bandit Big Rig Series event at Salem Speedway in Indiana. He had showed up the day before the event, and the track owner encouraged him to bring Mackvader to the next-door drag strip.
“I wasn’t there for more than 5 minutes, and this guy came over to me and said, ‘Do you want to race that thing?’” Mike says. “I asked him, ‘What do you have?’ He said, ‘I got a 2021 Powerstroke, tuned up, chipped.’ I said to him, ‘Go get it. Line it up. Let’s go do this.’ I gapped him every time.
“It goes pretty good [on a drag strip]. You got to be ready, just like with an old-school muscle car. It’s not easy, but you can do it. You power shift that semi-truck.”
In a different attempt at straight-line speed, Mike ventured to The Arkansas Mile to see how far he could push Mackvader.
“We topped out at 136 mph,” Mike says. “We hit 132 mph at the half-mile marker. Sometimes lessons are learned the hard way. I lowered the cab that year, and I put two small 90-degree bends in the exhaust pipe to get it out under the cab. Those two small bends created turbulence in the exhaust outlet. The turbo freewheeled and did not create any boost.”
He also doesn’t mind just showing the truck, especially to kids or for a good cause. Mike brought the truck to Highland Rim Speedway outside of Nashville for a Down syndrome charity event. Mackvader met Darth Vader, and they auctioned off rides to benefit the cause.
“It’s not always about racing,” Mike says. “We’re trying to put smiles on faces.”
The Bandit Big Rig Series shut down after the 2021 season. After that, Mike admits, he has struggled to find venues for Mackvader.
He autocrossed the truck during the Power Nationals at Nashville Superspeedway in September.
“It did very well,” Mike says. “The truck can be very nimble for as big as it is. It’s not going to beat out a whole lot of cars, but it will lay a decent time down, turn a lot of heads, and we’ll have fun doing it.”
Most recently, he entered it in an East10Drift event at Chilhowee Park in Knoxville, Tennessee. Mike learned some lessons that he’ll apply to another drifting opportunity.
“If I had a bigger track to play around with, I would use the engine brake a lot more,” Mike says. “When the engine brake comes on, it will slow down and lock up the rear axle and initiate the drift.”
[What in the world?! Did someone drift a Mack truck?]
In eight years, Mike Morgan and Mackvader have competed in a wide variety of motorsports across the entire nation. Admittedly, the truck has begun to show signs of its age.
“The truck has been beaten so hard over eight years,” says Mike. “It’s been over the wall, through a telephone pole, and took out the fence at Highland Rim [Speedway]. We took 30 feet of the soft wall at 140 mph at Bristol. It’s pretty bent up, and trying to repeat that same setup has been a challenge.”
However, Mike still has a few events on his wish list.
“I got an offer to bring it to a dirt track,” says Mike. “I want to run Pikes Peak before I’m done.”
Mackvader slingin’ mud on a dirt track? Mackvader doing a hillclimb? With 3000 lb.-ft. of torque pulling 13,000 pounds of truck? Who wouldn’t want to see that?
Join Free Join our community to easily find more Mack Trucks, Mack and Mackvader articles.
Comments
A 401 CJ
A 401 CJ GRM+ Memberand SuperDork
11/25/22 8:16 a.m.
If you race on the same course as this guy, the old phrase "..hit by a Mack truck.." might be appropriate.
On a serious note, it's sad that unlike in Europe and Down Under we've never embraced truck racing in this country.  Sure there were some attempts in the '70s and again I think in the '90s on oval tracks but it never really took off.  My guess would be that track insurance makes it too expensive.
I read an article in the '90s or early '00s where they came out with a "formula" to turn a Series 60 Detroit up to 1500 hp.  They wanted that much to make the racing series exciting for the fans.  They then approached Penske (the owner of Detroit Diesel at the time) and inquired about the validity of their formula.  The response was quite negative and read something like ...are you nuts?  If you run that much boost and that much fuel, you won't get more than 50,000 miles out of it....
They were looking for 500 miles.
11/25/22 9:49 a.m.
Trucks aren't cars. laugh
Curtis73 (Forum Supporter)
Curtis73 (Forum Supporter) MegaDork
11/25/22 11:57 a.m.
I love watching truck drags.  A 120k lb vehicle that can lift a front wheel is true torque.
MotorsportsGordon
MotorsportsGordon Dork
11/25/22 12:21 p.m.
They were looking for 500.
There is still truck racing at the short track level on both dirt and asphalt. Plus the odd truck drag racing.
MadScientistMatt
MadScientistMatt UltimaDork
11/25/22 3:54 p.m.
I heard that one thing that killed truck racing over here was the track pavement got ripped up - it wasn't designed for something that weighte six tons pulling one G.
03Panther
03Panther PowerDork
11/25/22 5:22 p.m.
In reply to A 401 CJ :
The guy I drove for some, got back to only one truck, and took a bit of time off from that. When he went back in it, he rebuilt the entire truck, plus detroit 60 driveline. Started at about 600 hp. Every mod since has gotten a bit better mpg, and they are up to at least 1200 hp. With longevity.
The bean counters that those folks approached, just didn't want to fool with it, 'cause it's doable. (And provable)
11/25/22 9:31 p.m.
... and that 1200hp is generated at about 2000 rpms.  Makes me wonder how many torques are at the flywheel.
te72
te72 HalfDork
11/26/22 2:53 a.m.
...and our local autocross group won't allow SUV's or trucks with 4wd. I should show them this. =P
Love the ingenuity on display here. Truly remarkable, when you consider that *each* slug that thing is spinning weighs about 40-50 lbs between the rod and piston.
A 401 CJ
11/26/22 1:49 p.m.
You can math it out for that 2000 rpm point but the short answer is - a lot more than 1200 torques :-)
buzzboy
buzzboy SuperDork
11/26/22 2:31 p.m.
I wish it made more sense to own a single axle day cab. A little truck with a pickup bed and a class 5 hitch would be such a fun tow rig and runabout(for how little I drive in the summer). And really look down at the brodozers
WVAnMN5iRIplaI0JjQyAaYu8w2baXQHorQCWJSXKgSO9qFm1CWK9W3UxH0xf4EhT
