Gasoline
Gasoline SuperDork
12/23/13 8:57 a.m.
NMNA
1970 Fiat 850 - $650 (Moulton, AL)
Needs restoring,most everything is there. Will crank and run but not ready for road trip. You'll get a notarized bill of sale because the state doesn't require a title for this year model. Call 256-565-7429, DON'T text!
Woody
Woody GRM+ Memberand MegaDork
12/23/13 9:08 a.m.
I don't think I've ever seen an 850 coupe before. That's really cool.
fasted58
fasted58 PowerDork
12/23/13 9:10 a.m.
and there's somebody's new challenge build car
JThw8
JThw8 PowerDork
12/23/13 1:39 p.m.
Woody wrote: I don't think I've ever seen an 850 coupe before. That's really cool.
Not a coupe, just a hardtop on the 'vert. There is an 850 coupe but it looks very different.
fasted58 wrote: and there's somebody's new challenge build car
that + this and a VW transaxle...job done, under budget
http://grassrootsmotorsports.com/forum/200x-classifieds/buick-v6-w-vw-adapter-back-up-for-sale/76185/page1/
BoxheadTim
BoxheadTim GRM+ Memberand PowerDork
12/23/13 2:05 p.m.
This is what an 850 coupe looks like:
Woody
12/23/13 5:03 p.m.
Wow, I was totally fooled by the hardtop.
bgkast
bgkast GRM+ Memberand Dork
12/23/13 5:07 p.m.
BoxheadTim wrote: This is what an 850 coupe looks like:
Ian F
Ian F UltimaDork
12/23/13 5:12 p.m.
I saw the first pic and thought, "Wow! A Fiat 850 that runs? I've never seen one of those!"
...and then I saw the second picture...
Ditchdigger
Ditchdigger SuperDork
12/23/13 5:55 p.m.
Nope. Factory. It is a Fiat 850 racer.
Woody
12/23/13 6:36 p.m.
Why hasn't someone handed him $650 yet?
JThw8
JThw8 PowerDork
12/23/13 6:43 p.m.
Ditchdigger wrote: Nope. Factory. It is a Fiat 850 racer.
Not denying it was factory, just not a coupe. I suspected it was a racer, I've only ever seen one other in person and it's sitting in a junkyard near here. I just couldn't recall if the top was a bolt on or an actual coupe style, memory aint what it used to be. Car in the ad is a bolt on top. First car you posted has the top molded in, but I believe it was originally a bolt on on all of the racers, just some folks have welded and molded them in at this point.
And if it is a racer and has some of the rare racer emblems and trim bits you could sell them and recoup this down to zero probably.
Woody
12/23/13 6:47 p.m.
Hypothetically, what are the chances of someone who is, say...6'1", 215 fitting inside one of these things?
BoxheadTim
12/23/13 6:49 p.m.
How good are you at self-origami?
SVreX
SVreX MegaDork
12/23/13 6:55 p.m.
Woody wrote: Hypothetically, what are the chances of someone who is, say...6'1", 215 fitting inside one of these things?
Depends on whether you puree him or just slice him.
Ditchdigger
12/23/13 7:23 p.m.
Not denying it was factory, just not a coupe. I suspected it was a racer, I've only ever seen one other in person and it's sitting in a junkyard near here. I just couldn't recall if the top was a bolt on or an actual coupe style, memory aint what it used to be. Car in the ad is a bolt on top. First car you posted has the top molded in, but I believe it was originally a bolt on on all of the racers, just some folks have welded and molded them in at this point. And if it is a racer and has some of the rare racer emblems and trim bits you could sell them and recoup this down to zero probably.
The top is a bolt on piece but there are quite a few other panels that would have to be swapped around if one wanted to put the racer top on a spider. I have a book around here somewhere that tells exactly what you need to harvest.
IIRC the Racer had a 911ish back "seat" that the spider doesn't.
The Famous EMPI fiat was a racer
Ditchdigger
12/23/13 7:25 p.m.
At 6' even, 215lbs and a 30" inseam, I fit into a spider with about 2" of headroom with the top up.
The seats do bolt directly to the floor. No chance of mounting them lower
JThw8
JThw8 PowerDork
12/23/13 8:00 p.m.
The top is a bolt on piece but there are quite a few other panels that would have to be swapped around if one wanted to put the racer top on a spider. I have a book around here somewhere that tells exactly what you need to harvest. IIRC the Racer had a 911ish back "seat" that the spider doesn't. The Famous EMPI fiat was a racer
twas this one that first made me think to combine this car with the engine and adapter combo and a VW transaxle that I posed up earlier :)
stroker
stroker Dork
12/23/13 8:36 p.m.
To me, that's screaming for a two-stroke snowmobile engine with expansion chambers sticking up through the deck like a pipe organ...
41euf3ZBaCcY1OIae93RJYjP54xYouKPLTCf90xIs4hgimCwvDmltJpmQJ82cFnX
