Day-7(2-hours): Minor progress - and setbacks.
I pulled the spark plugs, they were all fairly clean with no sign of oil nor any inconsistencies across the cylinders, which seemed like a good sign. So I installed the new batter & climbed in to check the status of the electrics.
When we picked up the car last weekend the key was already in the ignition & turned to "run", and the car was in neutral. Not wanting to risk discovering any problems we left both controls as-is. Since then I'd moved the shifter throughout it's range, but had no reason to mess with the key. My first discovery was the tumbler might need replaced, as it took several minutes of work to get the key back to the "off" position & be able to remove the key. The door lights were on, and the "security" message was flashing on the display. I tried the windows/wipers/lights, but none responded. I tried turning on the radio & was greeted with "1:00" on the display, but that flashed off after about a second, and none of the controls had any effect. I went over to the fuse panel, and checked & reset each one. They were all good, but the contacts were a bit crusty.
I climbed back in the driver's side and tried giving the key a crank. First thing I noticed is that pressing inward on the tumbler made the "check engine" display go on & off, but turning it to the "crank" position did nothing. I messed around with it a couple more times & did hear something that sounded like a server running briefly up in the engine bay, but no attempt to turn over.
Then I grabbed my breaker bar & tried turning the engine by hand again, now that the plugs were out. It wouldn't budge. So I tried cranking it one last time & did hear the starter engage, but still no crank.
So, any good tips to free a (hopefully mildly) stuck SBC?
Oh, the fuel pump arrived to day, which was earlier than expected, so I'll get the tank cleaned & it installed tomorrow.
I also picked up some spray adhesive today & got some of the loose fabric on one of the seat bottoms reattached.
