I was looking at distributor timing videos on youtube and it got me thinking. With cars becoming more and more electronically controlled, there are many pieces of old technology that are becoming forgotten, even if they are in use every day.
Back before hunter racks, alignments were done with string, rulers, tape measures, and degreed rotary plates.
What are some other 'lost arts' in the automotive world?
Balancing the wheels and tires while on the car. The old guy I went to 30 years ago would keep his forehead pressed against the fender until all the vibrations were gone.
Setting point gaps is also a thing of the past.
Topping up the water in your battery.
Fixing you vehicle of your choice without a scantool. The basics still apply, but what is causing the problem is about as clear as the mud in the deepest darkest ocean trench without a scanner.
Balancing twin SUs with a length of hose, or getting the right needle in one. I used to be able to do both 15 years ago.
lol dad and I where talking about how he got to where he could set the points by eye in our German Grenada (bought them cheap off base... drove it for a year or so and then sold it at profit to another military guy... think we had 3 of em... 2 sedans and a wagon over the years)
that is something that I will prob never learn to do... everything i've ever owned has had electronic ignition
4cylndrfury wrote: Stopping and putting the vehicle into 4wd...AWD is not the same thing kiddies
bonus points for getting you and your passenger to hop out quickly at the stop to engage the hubs ;-)... that was always fun lol
Zomby woof wrote: When was the last time anybody here aimed a headlight?
The real question is when is the last time I found a flat piece of asphalt that was right next to a wall?
Judging by the cars on the roads, nobody ever!
Knurled wrote: Paddling lead?
Dang! you beat me to it. That was goung to be my response. I am shocked that it was the very first one listed
I will go with panel beating/metal shaping
JoeyM wrote:Knurled wrote: Paddling lead?Dang! you beat me to it. That was goung to be my response. I am shocked that it was the very first one listed I will go with panel beating/metal shaping
ditto, me too.
Actually, me. Last night on my Grand Marquis. Three screws to adjust the L/R aim and height.
ultraclyde wrote:JoeyM wrote:ditto, me too.Knurled wrote: Paddling lead?Dang! you beat me to it. That was goung to be my response. I am shocked that it was the very first one listed I will go with panel beating/metal shaping
me three
Reaming king pins.
Adjusting brakes.
Changing to "winter" oil and "winter" tires.
Hand-mounting tires (I still do it).
"Breaking" tire beads by driving a car over the edge of the tire.
Hand lapping valves (I actually don't think this is such a good idea).
Pouring bearing (I've seen this done).
Hand crank starting (for me on many, many British cars + my plane)
Retarding timing for starting (see above)
Changing a canister oil filter.
Replacing gudgeon pins.
Understanding a vacuum gauge.
Push starting a car.
Jump starting a car by bringing the (steel) bumpers in contact and using just one cable.
Ridge reaming.
Working in a car from a "pit".
Changing valve seals without pulling the head.
Changing a "rope type" rear main seal.
Polarizing a generator.
Installing seat covers.
Adjusting GM points-type distributor with a hex wrench.
I could go on and on.......
