I am in the process of adding an overdrive transmission and nine-inch rear to my Ford and when all the parts are installed I am going to need a shorter driveshaft. I kept the driveshaft from the lincoln MK VII that donated its transmission and I think it will work, if I can keep the double joint at the axle end that was original to the lincoln. What is the purpose of the cardan joint and would I do any harm by adding it to a vehicle that previously did not have one?
![](http://www.jagsthatrun.com/Pages/images/Double-cardan-0246.jpg)
Had it running an driving yesterday to show someone the transmission, pulled the transmission by noon, and cut my cost for the swap down to $50 so far.
![](https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-snc6/177548_10102959418937614_1683807789_o.jpg)
Double Cardan joint, please. ![](/media/img/icons/smilies/grin-18.png)
Its purpose is that U-joints are not constant velocity, the more angle you put in the joint, the more the joint's output speed speeds up and slows down (twice per rev). Thus why U-joint clocking is so critical - the rear joint needs to cancel out the front joint and vice-versa.
All well and good, except you're not eliminating the speed variation (twice per revolution), you're just hiding it in 30-40 inches of tubular steel. There's going to be some NVH associated with that, acceptable for a Ford but for a Lincoln that just won't do. So, the double Cardan is used, which reduces the speed oscillation down to a level where it's not a nuisance.
Really good cars just use CV joints or Guibos if they have fixed diffs. Yes, I said something nice about Guibos. I like them.
