From Road & Track, June 2013, page 58. Caption reads "The skeletal 964 is one of two 911s here built for driver training." Photo is taken at Porsche's warehouse for factory vehicles. The photo only shows the rear of the car.
It haunts me. I just can't stop thinking about it. It's sorta like a locost, except you start with the vehicle then cut everything off and weld on a roll cage / exoskeletal frame. Sorta like an Exocet. I can't stop wondering how little it weighs. And for what possible reason Porsche did that modification for "driver training." That just doesn't compute. But I love the result!
How many other cars would benefit from this treatment? I want to see a 944 done like this.
David
And here's before they started cutting, but after they removed the composite panels and rollcage:
That's it. That's all that Toyota Team Europe left of the Celica shell. Then they bolted in a spindly looking aluminum (!) roll cage, stuck some flared overfenders on, put in a 350-400hp engine, and went flying through the woods.
I've been wanting to build a street legal 90s Impreza 2.2 like that for YEARS now. 135hp is a lot more fun at 1900lbs.
I admit that it's a whole lot easier to understand what the suspension is doing as you drive when you can actually see it. I was just getting heavy into racing when I got to drive a Formula Ford. Lots of little light bulbs went off as theories and principles started making sense.
chandlerGTi wrote: The whole article was pretty awesome.
The whole ISSUE was pretty amazing. I haven't said that about R&T in ages.
Huh, a friend has an X-1/9 done up like that. It wasn't any lighter than a stock exxie and they aren't that light for their size to begin with.
Careful consideration of the structure and the materials used is important if you're going for improved performance.
turboswede wrote: Huh, a friend has an X-1/9 done up like that. It wasn't any lighter than a stock exxie and they aren't that light for their size to begin with. Careful consideration of the structure and the materials used is important if you're going for improved performance.
I have cut up an Exxie.. there is a -lot- of steel down low on those cars in the box sectiont that supports the engine and rear suspension. Lots of watertraps too
