So my jeep started acting up, which becomes a concern as my C4 vette wont start due to VATS and ECM reprogramming and I don't know what I'm doing shenanagans.
I actually need this thing to keep working.
It is a 4.0, 5 speed manual, a 1998 with 120 or so thousand miles.
Road trip (on highway, 3+ hours) I notice the oil pressure gauge sitting at about 5-10 psi, down from the normal 35-40. No biggie at idle but I was turning about 2k rpm or so and the lifters are clattering like crazy. Clutch in to neutral and at idle the pressure climbs back up.
If I rev'ed it, the pressure would drop back to 10 or so. Got pissed and revved it aggressively (for a jeep, that means like maybe 3500-4000 rpm) needle wobbled, pressure came back up, but slowly (like over 5 minuites) dropped back to 10 psi at a steady 2k rpm.
Stopped to use a rest room, let it cool off and had great oil pressure (35-40 psi) for the initial 30 mins or so until it got hot again.
I had noticed in the past the lifters would clatter like crazy after long drives that got it hot. So this isn't the first time it has done it, just the first time I took notice.
Any theories? Should I put in 20-50 wt oil? Dump in some magic lucas oil gunk everyone with jeeps run? Think the oil pump relief valve is sticking open? Oil filter bypasses continually goofing up? Jeeps are only made to idle? Time to sell?
It does have an electronic gauge, with a sender I put in maybe 2 years ago, I don't want to assume the gauge is off because A) I have already blown up a motor assuming my gauges couldn't be right when I had no oil pressure and B) the HLA's were clattering like crazy.
Anyways, Thanks for reading!
