Frame and Engine Work
Per
Update by Per Schroeder to the LeGrand Mk 18 project car
Apr 16, 2009
Sponsored by
The rear framework has been welded to support the new differential.
We sprayed the framework with POR-15's gray color, which is a little darker than the original finish.
The Kawasaki KZ-series engines are pretty easy to work with. Larger-diameter bores will help us reach 1000cc.
We finished welding the LeGrand’s rear framework to support the new differential. Afterward, we gave it a coat of POR-15 paint. POR-15 provides a nice, tough finish that is theoretically impervious to fuels and solvents.
Next up, we’ll rework the KZ850 motor so that it displaces a full 1000cc—that’s the legal limit for our car in B Modified. Our plan is to replace the cylinder block and pistons with larger-diameter bores.
Comments
Per Schroeder
Per Schroeder PowerDork
4/15/09 7:49 a.m.
It's actually pretty thin, about as thick as a combination of primer and topcoat, but not as thick as a powdercoat. I like that if I need to fix something, I can just touch it up with a brush. Also, since it's nice and fresh, I will be able to see cracks a little easier.
I'm starting to strip the paint off the rest of the cage, there are at least 5 layers on there. yuck.
Per Schroeder
4/16/09 12:25 p.m.
We finished welding the LeGrand's rear framework to support the new differential. Afterward, we gave it a coat of POR-15 paint. POR-15 provides a nice, tough finish that is theoretically impervious to fuels and solvents.
Next up, we'll rework the KZ850 motor so that it displaces a full 1000cc--that's the legal limit for our car in B Modified. Our plan is to replace the cylinder block and pistons with larger-diameter bores.
ansonivan
ansonivan Dork
4/20/09 8:43 p.m.
Any plans for head work or cams or is that forbidden by B mod rules?
Per Schroeder
4/20/09 8:54 p.m.
Actually, yes. BMod allows pretty much anything given the weight/displacement limits for engine work. The head was already ported and had stiff valve springs and APE titanium retainers. I got a set of APE 410 cams and I need to clearance the head for them to fit.
Now, this is all just jerking around as I could also just replace the entire KZ with a ZX10R....but I'm having fun dinking around with what amounts to the original engine for the car (for now)
ansonivan
ansonivan Dork
4/21/09 9:33 a.m.
Very cool, I love the simplicity and ease of access on those old aircooled bike engines, I can completely understand the desire to wiggle a few more hp out of it.
dennisg
dennisg New Reader
7/25/09 8:11 p.m.
I've used pour 15 fuel tank liner and it will plug a 1/4" hole. its pretty thick.
Sponsored by
GRM Ad Dept
vAXEJdC6mBXfkNVvfHhcpCu8P9Wk27ZEH6kRdU3E1pw1P6aGxw8vq1r3qVIkZdjW
