Don’t let a frozen crank pulley bolt stop your timing belt change in its tracks.
Should you upgrade your clutch?
How to best join aluminum: Fasteners, brazing, soldering or welding?
8 secrets to bending and flaring pro-quality brake lines
Dang that's handy. But anyone got a crude diagram?
In reply to Junghole :
Take a closer look at the picture, I think you'll see it.
In reply to obsolete :
Ah. Thank you.
4th gear works well too
So, I guess taking out a spark plug and jamming a large screw driver against the piston is a bad idea
BTW this is more removing the stuck crank pulley bolt rather than the pulley its self.
Some times getting the pulley off the end of the crank shaft is a hole nother thing!
Displaying 1-5 of 5 commentsView all comments on the GRM forums
What you need to know before buying a lathe
Fitting tires and wheels when an off-the-shelf option isn’t listed
8 tips for welding like a pro
14 ways to go faster without spending a dime
Tips for making your wheels and tires fit better
10 common suspension problems–and how to cure them
How to choose the right tools for cutting metal
