1 ... 51 52 53
java230
java230 PowerDork
6/19/24 2:44 p.m.
IH Guys say the rear dumps may hit the trans mount. Grrrrrr
Mr_Asa
Mr_Asa MegaDork
6/19/24 2:46 p.m.
Trying to remember.  Isnt this a custom cross member?
Recon1342
Recon1342 UltraDork
6/19/24 2:53 p.m.
In reply to java230 :
The rear dump manifolds were for the 74-75 Travelalls that had the motor set farther back... I'd figured that would make clearance easier, not harder. Hmm...
java230
java230 PowerDork
6/19/24 4:51 p.m.
In reply to Mr_Asa :
No all factory.
java230
java230 PowerDork
6/19/24 4:52 p.m.
In reply to Recon1342 :
I'm not sure.... I did crawl way further back. I think it's doable. Just gonna be funky.
java230
java230 PowerDork
6/19/24 7:08 p.m.
Zero drips!
And windshield is In! The gasket from IH parts America is very good quality.
Recon1342
Recon1342 UltraDork
6/20/24 9:20 a.m.
Looking good!
I'll be very happy when my Power Wagon reaches this stage of doneness...
Dusterbd13-michael
Dusterbd13-michael MegaDork
6/20/24 11:22 a.m.
You're going to mess around and turn this thing into a really nice drive in truck in no time
java230
java230 PowerDork
6/20/24 12:24 p.m.
I am trying! Man the runs are bad in the sun tho.....
java230
java230 PowerDork
1/26/25 3:36 p.m.
I love efi. Sitting for 6 months and it. Just starts up.
But. I am also wondering if anyone wants to take this on to finish. It needs exhaust (I have most of the parts), fuel filler, glass installed (I have it all), repair air line (not having open headers will fix the melting issue), interior and dash.
I'm realizing I need a lift to do exhaust and don't want to pay someone 2k+ to do it. And I have my eye on a ctsv....
white_averson
white_averson Reader
1/28/25 9:28 a.m.
Oh man, I've wanted a Travelall done exactly like this for a while but it looks like we are on exactly opposite sides of the country
SpeedAddict502
SpeedAddict502 New Reader
1/28/25 2:20 p.m.
What are the full spec on it now?  Where are you located?
Any way to add AC to it?
NOHOME
NOHOME MegaDork
1/28/25 3:09 p.m.
In reply to SpeedAddict502 :
There is always a way to add AC.  I am in the middle of doing a self designed AC for the Molvo and once you get your head wrapped around the subject matter it is not too intimidating. Vintage air can be your friend.
In this case I would design the system around GM pickup truck parts since they can be had cheap and they are pretty much scaled to this project. The evaporator that goes inside is the fussy to fit bit. Use EZ clip hose fittings so that you can make your own lines with no need of a fancy hose crimper and take them apart to re-use when you mess up!
java230
java230 PowerDork
1/28/25 4:18 p.m.
Seattle WA
No AC currently, but was a factory (r12?) car. Compressor is in egine bay with no belt. condenser was removed (i have it). lines are tbd. Never tested, no pressure in the system when I got it, it was all disconnected.
It has an AC "box" similar to vintage air, but uses factory fan.
FWIW, all ducts under the dash need to be repalced I have not heared blower fan run. But its old school simple.
ShawnG
ShawnG MegaDork
1/28/25 4:22 p.m.
I've installed a couple Vintage Air systems. Even crammed one into a 34 Ford.
The only thing I didn't like was they only operate on recirculate.
java230
java230 PowerDork
1/30/25 8:30 p.m.
Well I did a thing.
NOHOME
NOHOME MegaDork
1/30/25 9:42 p.m.
And what a thing you have done!
java230
java230 PowerDork
1/30/25 9:45 p.m.
In reply to NOHOME :
Friend of a friend. Price was right. 95k miles. Needs a rear diff and REALLY good detail.
iansane
iansane GRM+ Memberand SuperDork
1/31/25 11:25 a.m.
Nice! The coupes look so aggressive. Don't think you can lower it too much with that driveway though!
java230
java230 PowerDork
1/31/25 1:59 p.m.
In reply to iansane :
Well luckily that is the seller's driveway, but mine isn't that much better.
I'm really excited. Need to get the diff done ASAP though
iansane
1/31/25 2:21 p.m.
6sp car? Plans for it? I know even thought my SS was boosted it wasn't long before I was shopping smaller pullies and such.
java230
java230 PowerDork
1/31/25 2:56 p.m.
Auto unfortunately.
I need to get it in and looked at before I do much in the way of mods. There is a little blowby and it burns 1/2 qt every 6 months ish?
I have looked at pulley, injectors and a larger heat Exchanger...... still need to do more research, the car kind of fell in my lap
mechanicalmeanderings
mechanicalmeanderings Reader
1/31/25 3:47 p.m.
I didn’t watch the video yet, but what are you needing out of the travelall?
is it really for sale?
java230
java230 PowerDork
1/31/25 7:24 p.m.
In reply to mechanicalmeanderings :
It's just a startup video. If the right offer came along it probably could be for sale. The RV definitely will be shortly,
java230
java230 PowerDork
2/6/25 3:41 p.m.
Well rear end is a 6k endeavor.
Prob gonna rent a diy garage and swap in a used diff. Garage is $400/12 hours.
1 ... 51 52 53
uczG0CbmEl6mMaw9wOBgi37d8GyifBfdWSF39tkKwp6mfTpUUYgXEQhfDrwiqMJr
